teal_mngri
🧲 New user
- Joined
- Mar 30, 2021
- Messages
- 2
My question is, can i combine LifeP04 with Li-Ion cells in series (both are 26650 format)? and my secondary question is, how can I tell if a 26650 cell is a LifePO4 or a Li-Ion cell (with a multimeter).
I have a 48v ebike battery pack (13s3p) that isn't charging. I opened it up and checked all the cell groups and one group was at zero volts
. My first surprise was that the cells were much bigger than the 18650s that I was expecting. It seems that they are 26650 size. I ordered some new 26650 cells, thinking i would just remove the bad cells and add in good ones. However it seems the new cells I ordered might be a different chemistry to the ones in the battery pack. My reasoning is based on the voltage readings and charging characteristics. The new cells I ordered seem to like being at about 3.7v and I can get them up to 4.2 very quickly (this seems very consistent with the curve for LifePO4). The existing cells in my battery pack are all at about 4.2v. I assumed they are Li-Ion based on the voltage, but I am not 100% sure. There is no marking on the cells. they are all a light teal (turquoise) colour and the have a very noticeable "safety caps" (not sure what they are called, but my understanding is that it's some kind of safety mechanism to cut off the voltage if the cell experiences pressure?. As a side note, I did try to revive the zero volt cells by using the end of a flat head screwdriver and trying to depress the diaphragm (Yes, I know this is VERY dangerous and I was not intending to re-use these cells, I was just curious to see if that's why they went to zero volts) but that didn't work (I followed a youtube 'tutorial' so I am sure I was doing it right, but anyway). So, to summarize, I am trying to replace the 3 bad cells in the ebike pack. They seem like 26650 size (based on my measurements of the cell dimensions), and the existing cells seem like lithium ion based on they all being at 4.2v, and the new cells I want to add into the pack (as a group of 3 parallel LiPO cells, connected to the rest of the pack in series) are the same dimensions (26650) but seem life LifePO4 (based on their voltage and charging characteristics). Also, the pack does have a BMS, I probably should have mentioned that.
My question is, can I add these LiFePO4 cells into the pack and what bad things could happen?
Many many thanks,
Dan
Many many thanks,
Dan
