YellowBuzzaroundEX
100 µW
- Joined
- Dec 19, 2021
- Messages
- 9
My 24V mobility scooter is a Golden Buzzaround XLS-HD.
It's Dynamic R50 controller specs say:
Continuous current 14A (driving full throttle on level ground).
Max current 40A for less than 60 seconds (accelerating or driving up a steep ramp).
I think that means (when accelerating or climbing a steep ramp) controller can draw a max of 40A for 60 seconds, then controller reduces back down to its usual 14A draw.
Am I understanding the above correctly?
The stock batteries are two 12V 21AH AGM batteries in series to make a 24V system.
I want to upgrade to two 12.8V 30AH LiFePo4 batteries in series to make a 25.6V system.
Here is the LiFePo4 battery I found https://astrolithium.com/products/copy-of-astro-lithium-12v-30ah-lithium-battery
Scooter controller rated continuous current 14A.
Battery rated continuous current 30A.
Scooter controller rated max current 40A < 60 seconds.
Battery rated max current 60A < 3 seconds.
Would that battery work, or would my controller overload the battery causing BMS shutoff or other problems?
