Ianhill said:
For a cheap dumb charger id keep it simple and first adjust the pot on board to the voltage you want to storage charge to and check its resistance then adjust the pot till the charger cuts out at full charge and check what it reads again now you have the two values to set your charger to terminate at differing voltages.
My previous post was in response to amberwolf and crazyfrog's posts. Should add that the
Mean Well HLG-60H-42A 42V 1.45A CC/CV Power Supply[/b] is only adjustable from 40v to 42v. The
HLG-60H-36A 36v 1.71A is adjustable from 33v to 40v (Amazon lists choice of 4 vendors $32-$45). This is perfect for bulk charging my 10S5P to 40V. Then separating the three Series connections between my 10S5P battery into two 5S5P packs. Then balance charging the two 5S5P packs to 4.05-07 cell volts with each 5S5P having their own 5S balance leads and their own Deans connector to balance charge each 5S5P pack using either my two 70-80W balance chargers or my one 150W duo balance charger set at one amp (retired so no problem). Still faster than a top-end (full) BMS resistance discharge balancing.
Ianhill said:
All this assumes your packs are using a bms ?
Realize this is only good "DIY correct" protocol assuming some reading this thread may not be an experienced DIY nerd that thinks outside the conventional BMS box with the know-how, tools and will. My 10S5P pack only needs 5-amp fusing. My etriking is 8-10mph with pedal assist (for excercise 75 yrs young) with a top speed of 12mph. No hurry so take it easy along the way. AND like docware i too see the logic of Shawn McCarty's DIY balance charging vs a non-smart BMS as found in most 18650 packs. This Youtube requirement ...
https://www.youtube.com/watch?v=pljSZcEwc8Q ... MUST be a little Nerdy, which usually makes life more fun & interesting
It only makes good sense to keep track of one's DIY pack with a cell checker and two single or one duo balance charger for bottom balancing and top balancing
if~when needed, especially as the 10S5P pack ages as all cells eventually get unbalanced.
Here's another little handy cell checker with multiply uses like charging my bike lights and phone when on an extended outing and camping overnight at one of my favorite secluded sites. Have a large Plano cargo container on the back of my etrike between the 24" rear wheel width with room for two 3S Lipos for plugging into the BattGo BG-8S Smart Battery Cell Checker and Balancer with Quick Charge Function. I bought it mainly as a quality cell checker for double checking cell voltages before and after balance charging my two 5S5P packs.The USB charging port for a phone or bike lights is on the right side. It's pretty neat (set me back $29 ~ Amazon) ...
