With a folded battery, it's tricky to get them to fold exactly in the middle of the metal, so the blocks stay straight when they are stacked. If the box is a snug fit, this could be a problem squeezing them in.
I'd consider making each block with copper tabs that come out. Stack them straight and solder the tabs together later,
And with 320 new cells, you have a lot of money in this battery, like over a thousand bucks? Maybe you should buy a better welder. Easy to ruin those cells with soldering,
Okay, let me try to wiggle out from your headlock.
On the folding. I might have a solution for the snug fit by gaining some room but it involves yet another issue. That would be removing the cell dividers and letting the cells touch and then squirting in the gaps between then good quality silicone. Roofing repair stuff. So I think I have room even if I let in the dividers as mu pack has changed with you all helping me.
MAKE TABS AFTER ERROR OCCURS - So about 'attempting' to fold the blocks and if it doesn't work, I am left with a misaligned battery that I cut at the bend and the length of that copper would be designed to, when folded, protrude about a quarter of an inch. Then the copper can be cut at the fold, overlap and be soldered once alignment is made.
IT ONLY FOLDS ONE WAY - I can make the length of the copper tight so that it can fold at really only one point so tight that getting a 1-2mm sheet of silicone between them, and it raising the top block, causes new concerns.
SAMPLE IT - Now after writing all that, your tabs all of a sudden feel quite loud and in charge. So I will be making a small 7 cells + 7 cells sample and folding to actually go through it.
On the soldering. Listen, in front of this group, I dare like a fool. I'm 'okay' at soldering, which says you win hands down. And yes, we can easily say near $2k for the cells. But my damn money has disappeared.
$60 = UGLY YET POWERFUL WELDER - If I gave you $60, could you fashion an emergency car battery welder (craig's list, hand making the pens somehow...struggling to make it work which when it comes to tool making, can do. my shop is solid), how would you build it? I'm willing to spend $60 to try. And we can tear down the Glitter to any level to sacrafice it for parts.
FIGURE OUT THAT DAMN GLITTER - I'll be taking apart the machine to see if there's anything wrong and make it usable.
NOW TO SOLDERING - Okay, I'll list my todos so that I make my side have a degree of hope.
• With Windex on a rag, simply clean both ends of all batteries and sides for glue.
• Dremel sand spots on each side of each cell for good and quick adhesion.
• Again, Windex only the ends.
• Set up the cells in total, + up and tape them firmly into one big rectangle.
• Apply not a dab but a thin coating of flux to each cell.
• After testing to know the size, cut lengths of the solder and bend in half and then place each solder on top of each cell (or in groups of 10-20, let's say).
• Clean newly made bigger flat/angular tip made just right to cover the entire + pad on these cells. Keep cleaning pad close and use it after each cell touch for small waist but killer predictability.
• Now touch each cell for 1-2 seconds. I have a tip temp from 400-650 degrees. The edge of the solder hopes to not look bubbly but more blended angularity into the cell. But if it looks bubbly, don't do another 1-2 seconds but know that your next hit will include pressure and copper and more solder, so chill.
• Now flip and repeat.
• So both sides of the cells have a solder spot. But a towel over them and get at the copper.
• Assuming all copper is cut, holes punched, edges sanded, tops and bottoms are sanded (for adhesion), now Windex them clean and pound flat with a mallet and wood.
• Each cell is soldered through a hole drilled out at each contact point. Holes seem to size out at ⅛" (perhaps 3/32"?). This lets soldering happen from above with visual understanding/confirmation, while also error correction if more solder is needed.
• On the underside of each copper sheet, solder a nice ring around each hole. It's ok if the hole gets filled..it most likely will on each hole. Just make sure the circumference is solder coated. And know the diameter of your + pad. Do not exceed it, and actually retract solder from near it. When both copper and battery get molten and join, one must account for accumulation.
• Addressing solder volume on both the tinned battery and copper sheet can be done by taking a Dremel and reducing the solder amount until you're sure that when both surfaces are joined, that solder /surely/ will not flow down into the + pressure release gap.
• Now that both sides are ready, and you have practiced on junk cells, start on - side as it's easier. Get them all soldered! Remember, after each tough, the tip is not just cleaned by shoving it into a Brillo pad alone but wiped with a quick tip grab with rag in hand.
• However, the copper sheet needs to be held down to the cell while and as solder cools. Make a stick out of thin yet rigid metal or wood that has a tip that is flat and angled and a slot cut for soldering tip movement. Think of a tiny spatula with a half circle cut out it's leading tip. The part that tries to get under that egg.
• Press down with one hand and heat up and solder with the other. Hold down with the spatula hand until the solder goes from shiny to a mat finish. A dream bench to do this on would be a bench with matching holes so that a battery tester could be contacted on both sides to check the connection.
• When the connection is made at the points where folding is going to happen, one can see the results and possibly repair if the folding makes a connection disconnect.
• Once finished, battery test it all and continue with solidifying it and boxing.
How did I do boss?
