pendragon8000
Just note there is a difference between thermistor (variable resistor based on temperature) and thermostat (switch based on temperature) sort about my mumbling in the video may have been confusing the two.Rix said:Pendragon, if welding up side down isn't a factor, try 5/32 or 3/16 inch 7024 electrodes for your welder. This rod can be used vertical and horizontal, oscillating or not, just not overhead and is the easiest rod I have ever used on an arc welder. You will be amazed how pretty the welds come out. BTW, thanks for the info on the thermasistor, appreciate that.
Rick
Edit
Thanks for the welding advice. Was just a quick tea break post
