Tincan
Howdy,
Well after working on my Vespa type scooter and reading the fun other members here have on their bikes i thought i would have a crack at converting my Mongoose i have collecting dust.
I mentioned it to a family friend what i was going to do and said they had a chinese bike they purchased off ebay that they no longer use and im welcome to have it.
Got it home and pulled it apart.
The tire on it was so thin.. so on with my existing tire, the rear drop outs needed a little "adjusting" to suit the wide berth of the new wheel.
Now being that is a geared freewheel, I'm not expecting anything fast or strong out of it, more just a bit of fun / assistance for a longer ride.
The controller is TINY! but i guess it doesn't need to do a whole lot.
The bike it came off didn't have a throttle either, which i thought was a little odd, only had a pedalic sensor.
Not having a clue how a pedal sensor worked, i decided to just hook it up to a regular 3 wire throttle off my scooter.
Kinda worked, only it was full throttle all the time and when you wind it on, it turned off... Need another solution.
Searching through the bowels of the forum i found a wiring diagram for the controller and the other plug that wasn't used, is actually a throttle input!
Needless to say 30 seconds later i had the thing running as it should!
Took it out for its first ride today and yeh, different kind of experience to the scooter, that's for sure.
Being that it's only a 24v system, i wasn't expecting ball tearing performance, but i was actually shocked at how well it did on its own. Up a hill it would struggle, but pull a high gear, one that would usually be hard to pedal, and it was like i was in 1st gear, so easy!
Need to sort out my brakes. I had to say bye to my rear disc to fit the motor, didn't have a mounting point for the disc I still have a disc on the front that does very well, just would be nice to have two.
So... Plans...
-Get the battery pack and controller out of my back pack. Was good for a test, but bugger having it in there all the time.
-Lipo.
-Lyen Controller. I want to go 48v so this one will be binned.
-New battery position
-Purchase a thumb throttle. It looks dicky with my grip shift AND a twist throttle.
-Brakes. Not sure what / how yet.
Anyway, pics! (forgive the iPhone 3g quality)
Motor with my mongoose tire on it.
"Adjusting" the dropouts
Mounted and motor wires hidden.
No rear disc
Back from my first ride, note Battery and controller in backpack
Controller - Told you is was tiny!
Dodgy photo alert - Motor Phase and throttle wires in a DB9 serial lead.
Really need a thumb throttle...
Let the mods begin
So... Plans...
-Lipo.
No rear disc
Let the mods begin
