Hello all,
I took my e-bike out for a ride yesterday and ended up putting on 48 miles. Perfect day, after not being able to ride for a couple of weeks due to the smoke in the air. 90% of my riding was using pedal assist, and mostly on level 1, since most of the riding was pretty flat, with a few moderate inclines. On the way back, after about 40 miles, I noticed some strange behavior on 3 or 4 occasions. From a standing start or from very slow speeds, pedaling the bike before PAS kicked in feels like pushing against the motor, as though it were braking. At one point I stopped and hand turned the wheel and could feel the resistance. After PAS kicked in, or if I used the throttle, everything went back to normal, and stopping and starting required the same pedal effort as before.
I'm wondering if this is a common problem with an easy solution. The motor, controller and battery remained cool during the whole ride, but I did do 3 275 ft climbs of maybe 10% which shouldn't be an issue based on the bike's observed performance. Battery settled at 51 volts after the ride, but I did see it sag to 48 volts on the last climb up to my house.
Thanks ahead of time for any insights.
Here's my setup:
Motor:
26” Rear Hub - MXUS model: XF 40 1000W 1610 0020
48V, 1000W
Controller:
Sine Wave : KT36/48SVPRK-SLSO2G
Maximum current: 45±1A
Rated voltage: DC36V/48V
Rated current: 22A
18 MOSFET
Display:
KT-LCD3
Battery:
Li-Ion – Unit Power Pack - 52V, 20Ah, 30A BMS
Halfway point in my ride, Yerba Buena Island in the middle of the SF bay. The Bay Bridge has a walking/biking path from my side of the bay to the island.
Here's my setup:
Motor:
48V, 1000W
Controller:
Rated current: 22A
18 MOSFET
Display:
KT-LCD3
Battery:
