Postby bunya » Mon Dec 21, 2015 5:30 pm
I asked myself a similar question about the high losses in no-load condition. I don't think Rm has much to do with it though, copper losses are less than 1W at 6000rpm whereas total losses are approx 150W. My guess is the IPM design with the embedded magnets results in more hysteresis losses (97w) when switching at 400Hz then most other designs. Eddy losses are also high 0.5mm laminations etc. I don't think the poor fill factor has much effect on no load current either but am not sure.
Miles said:Quite.. Now you have experience of the JM1S and the JM1. How could they be improved on, for traction vehicles? As opposed to propeller driven ones.....toolman2 said:to me it seems that we have found ourselves alive NOW to design our electric weapons, NOT at some point in the future -whilst its interesting to ponder which way things might go, its very difficult to design and ride machines with parts that are yet to, and may never exist.
The 46p Joby (JM2) is also interesting. Optimised for torque density, rather than power density (as we're frequency limited).toolman2 said:Ive given this some thought Miles and other than being greedy (maby for more torque via extra iron and copper via tooth length etc -and thats not realistic with in the same dia without making the rotor smaller) cos the other bike components prolly max out first, the motor really is spot on, and also very similar to your designs. :wink:
Compare the continuous torque density of the JM1 and the JM2S, which are close to the same mass....speedmd said:Interesting comparison in the JM1 and the JM2 given the difference in top end RPM
But the JM2S gets such a high torque density, partly, by (more than) doubling the pole count and they're already using 0.12mm laminations.....speedmd said:Doing so and also not giving up the high end revs would be a no-brainer.
All I got at this point is the overall DIA of the rotor and its 5 1/8" Or 130mm I will try to get more info asap. But I want to know terminal RPM for the rotor it self. That's all the really matters.crossbreak said:Do u know shaft dia and bearing size? I can do a DIN calc analysis on overload fracture. Won't be as accurate as calcing the while calc but it will give you a number. I also need sprocket effective dia too.
Miles said:But the JM2S gets such a high torque density, partly, by (more than) doubling the pole count and they're already using 0.12mm laminations.....speedmd said:Doing so and also not giving up the high end revs would be a no-brainer.
i'm not so sure if this really exists. I cannot find a valid conceptual model that proves why a motor with more pole count shall produce more torque/should be higher Km². If you just want thinner yokes, you can simply use high slot count like the leaf does. You most likely get a better winding factor: A 12n8p has 0.866 while the 48n8p has 0.966. An incrase in Km² of 24%. Both being the same pole count. the 48n will be more expensive to producePossibly, there's a small advantage in torque from the pole count but it's not clear why....
Me neither, but it showed in the simulations I did.crossbreak said:i'm not so sure if this really exists
Good luck with that....crossbreak said:If you just want thinner yokes, you can simply use high slot count like the leaf does.
Miles said:Advantages of higher pole count:
For a given O.D. this allows either, an increase in copper cross-sectional area or an increase in gap diameter and area.
madin88 said:how would two outrunner motors compare in terms of copper fill?
both have same gap diameter and same stator width, but one has high pole count and one has low pole count.
Since the back iron of both stator and rotor are thinner. But the sum of the tooth widths will be the same, as the ratio of slot width to tooth width shall be the same for equal torque abilities, 50%/50% for example.Miles said:You need less iron for a higher pole count
Nopecrossbreak said:Edit: cross-section of the stator backiron should depend on slot count ..
crossbreak said:that brings me to the idea of an axial sandwich motor that lacks of stator back iron: One rotor, then the stator and then another rotor: Still two backiron parts, but they both are in the rotors. These virtually have no eddy currents and need less cross-section than stator back iron does![]()
