farrerzack
- Joined
- Oct 28, 2014
- Messages
- 28
My current setup is using a sk3 6364 213 kv motor on 6s batteries. I originally was using the stock 9mm gearing kit from torquebaords (which I believe was using 14t/44t). I recently upgraded to an 11mm belt kit, also from torqueboards which almost certainly has a 36t wheel pulley and a slightly larger motor pulley. The new belt is awesome, but I definitely noticed that the motor struggled much more at lower speeds (as expected, it has been geared up) while also getting much hotter. What confused me is that the top speed has not risen but actually seems to have gone down slightly. Because of all of this, I lowered the timing setting on my esc, which seems to have helped somewhat with the heat issue and the low speed problems. My top speed hasn't gone up though, and it still feels lacking in the top end.
My question is whether I should adjust my timing more or look into either a lower kv motor or a smaller rear pulley. I know a lot of people seem to use the 192 kv or even lower motors, but I've also seen people using 245 and 280 Kv motors just fine which leaves me confused as to why it seems my motor is struggling in the torque area. Any insight is welcome,
Zack
Zack
