xyster
Man... I woulda lost a bet that you made that name up. :?
I lied. Just testing your "power" of insight and intuition. :wink:
xyster said:Man... I woulda lost a bet that you made that name up. :?
Tiefighter Durden said:....xyster said:One more Socratic query: if 100 volts 10 amps accelerates your bike at the same rate as 10 volts 10 amps (as you said you thought it would), what happens to all the extra power (90 volts X 10 amps = 900 watts had to go somewhere!)? I'm saying the extra wattage (power) goes to faster acceleration.
Ja, I'll contend that if 10V gets you to max 100rpm in 10sec, 100V will too... but the 100V test will continue to rise in RPM to 1000rpm or whatever.
xyster said:Another question:
Look at where peak torque is on every motor in every configuration on the hubmotor simulator:
http://www.ebikes.ca/simulator/
It's at zero speed, right?
And torque decreases between zero speed and top speed, right?
What does your intuition tell you:
Is peak acceleration near the point of peak torque (at 0kph)?
Or is peak acceleration nearer the point of peak power (the redline)?
xyster said:The way I see it, the crux of your disagreement with reality is nicely summed up in this quote below, the debate boiled down to a simple yes/no.
fechter said:Guys, guys, ... you're making my head hurt.
Just for simplicity, consider brushed motors.
Acceleration is another matter. Force/mass=acceleration. Force will be porportional to motor current, minus the force needed to overcome wind resistance, rolling resistance, and grade. Generally speaking, acceleration will be the greatest at near zero speed.
Safe: your formulas look good. They make sense to me.
eP said:Acceleration depends on torque not the power out.
safe said:I'm glad you commented because people here respect your opinion.
But let me add that when it comes to acceleration it's true that Force/mass=acceleration... but the force (torque) coming from a motor has to go through the gears before it actually accelerates the bike. So let's make an example:
If motor "A" has a 1:1 gear ratio and 100 Nm of torque it will provide a torque of 100 Nm at the rear wheel. If bike "A" weighs 100 kg then with a = F/m we get an instantanous acceleration of 1 m/s. (these are easy and round numbers)
If motor "B" has a 1:10 gear ratio and 100 Nm of torque it will provide a torque of 1000 Nm at the rear wheel. If bike "B" weighs 100 kg then with a = F/m we get an instantanous acceleration of 10 m/s.
Thanks for the support again Fechter...
fechter said:Looking at the power balance in a system is another way to calculate things based on conservation of energy. There is almost always more than one way to get the same answer to a physics problem. While both approaches may be valid, sometimes it is easier to visualize one over the other.
Once you transcend the laws for electric bikes you effectively step into the motorcycle world. You would then need a motorcycle license, motorcycle training classes, registration, money, money, money, etc... So the goal of staying "under the radar" is a high priority for me personally because I don't want to be creating stuff that could never be sold legally as an electric bike. (even if it has to be sold in a slightly restricted manner)
xyster said:Just wire in a simple series/parallel switch on a 36v/72v system and voila', you've got on-road legality and off-road thrill.
Lowell said:I don't think any motors will be banned. The responsibility will come down to the manufacturers and retail outlets which sell legal ebikes.
If you can pass those three rules then you have lawsuit protection.
xyster said:...Though the vehicles were legal and safe when operated properly, lawsuits forced three wheeler manufacturers to stop making them.
