Hello,
I recently found this forum and I have been reading through books on motor and ESC designs. I am not familiar with the forum rules and I am a little concerned by the lack of new topics (i.e., most topics are quite old but keep getting new posts in them); so feel free to nuke this post if this is inappropriate. I had a few questions that I haven't found answers to:
(Note: all of these questions are in the context of an axial flux motor design. I don't know if that has any impact on the questions or not)
1) I am trying to understand the design differences and benefits to 6 phase motors over 3 phase. The best article that I have found explaining 6-phase designs is located here: https://ietresearch.onlinelibrary.wiley.com/doi/full/10.1049/elp2.12133 (there is a wiring diagram in there as well; I assume the A+ and A- actually use the same wire and the difference is the timing of the gates). Is this a typical 6-phase design or is this different/novel? If this is different, than could someone explain or point me toward a more typical wiring design?
1a) If the linked-to design is typical, it would seem them that one could have 9 phases or 12 phases with a sufficiently large (diameter) motor design. The relative benefit would be reduced amperage per phase at the expense of an unusual or complex ESC.
1b) I have been independently trying to imagine other 6-phase designs and what seems like an obvious approach would be to have a multi-stator design where the second stator is offset (rotated) by half a slot width. This would obviously require a second set of writing with independent timing that would ultimately become phase shifted similar to the design shown at the link above. However, this would require a second stator.
2) For many of the motor wiring diagrams that I have seen, it seems like the windings are in series (for a 3 phase design, for example). Wiring the stator windings in series would require larger wire size relative to a parallel design (e.g., with a thicker gauge "bus" wire around the motor perimeter). Is there a good reason not to do this?
3) In one of the books that I am reading there is a diagram showing a relative phase shift between the PM rotors in a two rotor, interior stator design. However, the book does not discuss why (or why not) one would decide to pursue this design. (An example of this is shown in Axial Flux Permananet Brushless Machines, pg 11, variable "Xo").
4) I have seen numerous posts using VESC Tool. Is VESC Tool a common tool used by many different controllers? Is it up to the controller to support the software? I am trying to understand the ecosystem there.
Thank you and sorry if any of these questions are redundant.
