ScuderiaEV
- Joined
- Jun 16, 2009
- Messages
- 2
Motorcycle aerodynamics article;
http://www.tonyfoale.com/Articles/Aerodynamics/AERO.htm
markcycle said:I now have over 50 parkway miles on the Lifan with the MHM-602 motor.
Here is some data
Top speed 75 MPH @ 94 volts and 100 amps (head down behind windsheild) 65MPH sitting upright
Power usage: 100 to 112 watt-hour/mile
Motor temperature after 12 miles of continuous parkway miles air temp about 70F
Outer rotors case temperature 57C
Stator temperature 82C
No thermal runaway observed
No extra cooling sealed motor
Looking forward to testing the motor on the track with Jay64 riding at 200 to 300 amps, I'm hoping for somewhere between 100 and 140 MPH depending on how slippery the bike is.
Did you ever get a chance to measure winding resistance for the 602?
Dave
Mark
markcycle said:Looking forward to testing the motor on the track with Jay64 riding at 200 to 300 amps, I'm hoping for somewhere between 100 and 140 MPH depending on how slippery the bike is.
Mark
liveforphysics said:markcycle said:Looking forward to testing the motor on the track with Jay64 riding at 200 to 300 amps, I'm hoping for somewhere between 100 and 140 MPH depending on how slippery the bike is.
Mark
On a superbike with full fairing and a rider down in a deep tuck, it takes about 75-85hp (56-63kw mechanical) continuously delivered to the rear tire to reach 140mph.
This is a motor featuring a double wide 530x stator. If you look at how that works out, you have a motor with slightly less power potential than a pair of 530x motors (if you want a technical explanation for why that is, I can do it for you).
If we give a generous 85% efficiency, you're looking at needing a continuous 65-75kw. In other words, at 120v, you would need to be continuously dumping ~541 to 625amps.
michaelplogue said:Mark -
Two questions:
First: With this motor being - for the most part - based on the Crystalite design, can we assume that we would not be able to do the Delta-Wye modification with it?
That's true I tried Delta and it didn't work.
Second - would there be any difficulties with fitting this motor into a 15" motorcycle rim (36 hole)?
Spokes are going to be very short but doable. Whats more important is the tire and the outer circumference of the tire. What tire are you planing on?
Thanks!
todayican2 said:Mark, I know I have asked this before, but it seems the motor is exceeding your expectations and I guess it should be asked again.
with say 120v nominal, and a say 700 or 800lb trike, a) do you now think the motor will have the "snot"?
and b) do you think the hub, laced with spokes will have the lateral strength?
pardon the potentially newbie question, but after talking with Matt (Frodus) on another matter, I like his integrity and would like to possibly use the syncromotive controller, good match?
Mikey said:Mark,
45 kW peak for the 600 series...Would you hazard a guess as to the stall torque of such a moto. As you know I have some good data on real world scooter acceleration so would be curious to know if you are geting close to these numbers (500cc numbers that is).
For non spked bikes have you thought about an extended hub that could bolt directly to a rim (like two piece alloy wheels)
WDYR?
Mike
markcycle said:The smallest rim would be a 15 inch rim, even then don't expect to much over 50 MPH. I really recommend a 17 or 18 inch rim to get in the 50 to 80 MPH range with 72 to 144 volt pack.
michaelplogue said:markcycle said:The smallest rim would be a 15 inch rim, even then don't expect to much over 50 MPH. I really recommend a 17 or 18 inch rim to get in the 50 to 80 MPH range with 72 to 144 volt pack.
That would be perfect for what I'd be looking for. It would be used for city riding with some very steep hills. The smaller wheel would be even more to my advantage for the better torque.
markcycle said:With a hub motor the tire circumference and voltage are both adjustment variables for no load speed. This is why I am always interested in the tire being used and not just the rim size.
Mark
Jay64 said:markcycle said:With a hub motor the tire circumference and voltage are both adjustment variables for no load speed. This is why I am always interested in the tire being used and not just the rim size.
Mark
I was actually just talking to my old tire sponsor about this two days ago. I was asking if they had any good race type rubber in the 18" size and he suggested a 17" tire with a taller profile to get near the same circumference. As far as good race rubber is concerned, 17" is very popular. I did find an Avon 18" tire that is used on a lot of vintage racers though. Looks promising. Mark, have you looked into any wider rim options? I think for the sportbike test bike we have been talking about, I would like to try and get as wide a tire as possible for the corner speeds I am going to try to pull off.
