markcycle
Jay64 said:Ok, I just saw that you had mentioned earlier that it had "push you back in the seat" power. Sounds good to me. What dimensions do you need from the swingarms? I've got quite a few bikes/swingarms around here I could measure up for you to save you some r&d costs. I've got access to XR100, XR200, DRZ125, TS185, '88 CBR600, '02 GSXR 600, '06 GSXR600. I also could make some phone calls and get some dimensions for RMZ450, DRZ400, and some various other ones. What is the volt limit for this motor? What do you think the top speed could be with more volts? I saw in a really early post something about 60mph. Do you think this is still abtainable with higher volts? I really like the black finish, but some people really like the bling factor. Are there any plans for having different colored hubs in the future? It's not like you have to hide it like in a bicycle in some places. If it is aluminum, then you could have it anodized different colors.
Also, have an option to go with some light weight/performance rims such as excel.
http://www.rkexcelamerica.com/mx_excel_rims.html
Lots a really good question here
First Jay thanks for the offer If in your spare time when you get a chance if you could give me the spacing between the arms at the axle mounting and axle Diameter for the different bikes you mention above, that would be great, a real help.
What is the volt limit of this motor?
I'm rating the motor at 96 volts or I should say a 96 volt battery which hot off the charger will be higher.
Top speed of the motor
Top speed is hard to predict, it depends of the Aero of your bike. That said 100 volts and 100amps will get you 10KW at the battery that's 13HP so 11.5 to 12HP at the tire. Now do 2 wheel drive and Wow that will be a fast bike!!
Color can happen, not a priority right now. Powered coat seem better if I go with a cast side cover If machined them anodizing is possible (cost is always a factor)
Just to review voltage for this motor
As we all know wheel diam. is the gear ratio for a hub motor.
For a Wye connected motor
I am using a 18 inch rim with a 3 inch tire, which is big for a rear wheel of a motorcycle (not width but Diam.). My motor at 70volts under load is doing 45MPH and pulling just under 60 amps (the motor is running cold at that power level) At 96 volt the motor will draw 82 amps (better) Now how does that relate to real world speed well its hard to predict since air resistance goes up exponentially with speed. At speed a good areo bike is much more important than weight so that's where the effort should be when you got about 12Hp to work with.
Delta connected motor
For 16 inch and 17 inch rims I am going to connect the motor Delta otherwise the voltage need would be to great.
For the delta connected motor I am rating the wheels 60 volts for the 17 inch and 72 volts for the 16 inch. The current will need to go up by a factor of 1.73 to maintain comparable power to the wye connected motor.
The unsprung weight issue can be addressed to some degree by doing just that. Brand name rims such as excel are expensive but for those who want them sure. Excel rims will make this hub shine by shedding pounds off the wheel compared to a steel rim.
Happy New Year all
2009 the year of the Motorcycle Hub Motor
The year you can easily put enough batteries in that E-Motorcycle to go the distance.
Mark
