mistercrash
Cost is not the issue, it's just that I want to be sure I get the correct stuff. Anyway, after looking it over again, I figured some of the things I would need. Here's a link to Albert's schematic http://www.avdweb.nl/Article_files/Tech-tips/Spot-welder/Spot-welder-controller-circuit.jpg
A couple small PCBs
One 15 ohm 50W resistor with aluminum shell
One 390 ohm resistor
One 220 ohm resistor
Two 330 ohm resistor
One 100 ohm 1W resistor
One 100nf 400V capacitor
Two BT151-800R Thyristors with two heat sinks
One MOC3023 optoisolator triac driver 6 pin
One four pole screw terminal block
I found all of it on ebay.
Not sure what a BDC switch is, it's installed on the Arduino http://www.avdweb.nl/Article_files/Tech-tips/Spot-welder/Timer.JPG
Not sure which switch to get for the ''weld current switch''.
A couple small PCBs
