Mountain Board Truck dimensions..-Alien Drive
beetbocks
Hi Guys..
I've had loads of request for a kit to suit Mountain Board Trucks,,so im hoping you can help me..(as i don't own any)
I need the dimensions of popular trucks such as:-
Scrub
MBS Pro matrix
MBS Vector
Trampa Infinity
I need the cross section dimensions..
well i wanted to see the product in the flesh.. really nice finish BTW.
I have actually been thinking about this design (and using 3d prints ) for quite a while now..i just needed a kick up the arse to get me moving.. :D
Looking nice Beetbocks.
The measurements are about 22mm each. I took photos for you:
Width: 21.98mm
http://gourmetpixel.com/tests/bens/eMTB_leafe/mmWidth.jpg
Height: 22.20mm
http://gourmetpixel.com/tests/bens/eMTB_leafe/mmHeight.jpg
These trucks are a bit of a nightmare as they are tapered, plus they have 2 flat sides and 2 rounded sides (they are not truly round nor truly square), and they have the brake mount hole. Looks like about 13mm between end of truck and start of brake mount where the truck is not tapered at least:
http://gourmetpixel.com/tests/bens/eMTB_leafe/mmToBrakeMount.jpg
Hope that helps. Shout if not. If you're really confused I could lend you one for a while; I'm not using this board right now.
that's great thanks..yes the brake attachment may be an issue..ill see what i can do..
thanks again..
I see your using the MBS pro wheel..
I already have the Drive Hub designed and made for that..:)
thanks again..
hello
this is great !! i've been looking for a Drive Hub for my MBS pro.
is this for a 15mm belt ?
what is the pitch and type of belt ?
I hope to have a small initial batch of 10 Drive hubs available in a month or so..
You can use a 9mm belt,15mm belt of even a sprocket..im just working on the best systems..
First initial test batch of the new USB Mount (Universal Bracket Mount) has arrived along with profile clamp rings for 6 trucks..
As always i'm super happy with the finish and quality of the parts-
I'll be sending a couple out to some good customers to test and give there opinion.
These mounts are Universally mountable on both sides of the truck and can be used with any of the drive ratios I sell..
So one size fits all folks..
Not to mention that fact that you can also 3D print a clamp ring for almost any truck if you can design and print it..
Current Truck fitment..
Caliber
Paris V1/2
Surf Rodz indeez (Hex )
Dont Trip Poppy/and Lucys
Gullwing Sidewinder
Attack Black start RKP.
and with a small amount of filing pretty much any truck can be used..
Im still waiting on some dimension for the Vertigo and Matrix Trucks so i can print some test clamp rings..
I also should have the first batch of Rockstar Hubs arriving soon..
Nice to know :)
The hole for the adapter what is the diameter ?
About the MBS trucks I order a pair of the new matrix pro 2 that I think will be better to use with this arm.
Here is the link
http://shop.mbs.com/accessories-486/mountainboard-trucks-suspension/mountainboard-trucks/mbs-matrix-ii-pro-truck-system.html
Kaly said:
Nice to know :)
Here is the link
that's great - the outside diameter is 30mm..
Caliber
Paris V1/2
Gullwing Sidewinder
are you offering these for sale? If so i'd be interested in using them and providing you feedback based on my results.
my only concern is how to tension to belt if all the holes are mountable and do not offer adjustability?
edit: looks like there is a sliding groove on one portion of the mount for that. PERFECT :D please let me know,im interested.
-James
yep they will be for sale..in the hope fully a month or two..- i just need to use the batch for some promo shots etc..- i may just wait until after Xmas as most of my customers will be out snowboarding for the next few months..(lucky buggers)
As you pointed out they are completely adjustable.. they adjust just the same as my old version (except 6 bolts now) - the main difference is the multi format clamp ring which is just so versatile..:)
I will list them on my website as soon as there available and the cost should be around the same as my present kits..
[youtube]GybVXMr7O3k[/youtube]
Hi!
Have you already test the clearance for motor wires to turn them trucks side properly?
