johnrobholmes said:
John in CR said:
PS- Johnrobholmes, do I need to include discussion of how CG height has no effect on lean angle (except for the negligible effect due to tire width, which we can ignore for bicycles), or have you let go of that misconception already?
Go ahead and try to find it, or better yet try it out! I already know how bikes handle with different CG heights. Simple physics, an object with a lower CG can lean farther while keeping support underneath. A clown punching bag can lean further the heavier it is at the bottom (lower CG), same as a rider balancing in a turn. You must have support underneath to be in a stable turn.
I agree that you can fall into a turn initially, but I maintain that the point of reference for any object is the center of mass (gravity). When a rider "falls" into a turn with a rotation about the tire it is not the same as a tree falling. The rider is in motion, he has a change in his direction with the fall and the tires must follow to keep balance. The "fall" is the first part of countersteer when the tires are coming out from underneath the CG, as the object has already entered the turn but the support has not. This is a relative relationship. The turn is not referenced from the tires, it is referenced from the CG of the object (which is the axis of rotation for any falling object).
Johnrob,
Here's a discussion including the math supporting that speed and turn radius alone determine lean angle, not CG height.
http://www.msgroup.org/forums/MTT/topic.asp?TOPIC_ID=312 . I do believe that CG height affects the rate of change in lean angle, so I think I understand where that perception comes from.
The blow up punching clown obtains its self righting behavior from its wide somewhat rounded base and significant weight there, and isn't really irrelevant to the lean angle discussion. It can however be adapted to my point about very low placement not affecting CG in terms of balancing. First narrow its base and make it more rigid, like a bike tire. Then put some weight at the top to make it more like a bike in terms of balancing and leaning. Now changing the amount of weight at the bottom has no significant effect on balancing or the forces required to keep it balanced when imbalance occurs when you lean it over.
Regarding "fall", I'm sorry I used the word. I did so because you can actually feel yourself falling into a turn, and because the bike is like an inverted pendulum, the fall is through increased lean like a tree. Of course a bike is in motion, and it's the speed and turn radius that result in the force to slow and stop it, as well as reverse it. I wasn't talking about the lowering of the CG during countersteer as falling, though we have no disagreement there.
The disagreement lies in the roll and rotation of the bike. During countersteer we agree that rotation occurs around the CG if the rider maintains a rigid position wrt the frame, though the axis point of the frame rotation will typically will be lower because the rider changes position. Once you steer back past neutral to actually turn, the bike can only increase lean angle by rolling around the axis of the contact patches.
Now maybe Safe with his racing style of riding and Papa with his recumbents, I don't know b/c I've never ridden one, get to or near full lean during countersteer and hold it through the turn, but I don't on my upright bike. On a typical turn I let gravity create most of the lean unless it's a sharp turn. A gradually decreasing turn radius slows this roll or "falling into the turn" motion until the middle of the turn where the radius becomes small enough at that speed to overcome gravity and lift back upright.
To address Tiberius' earlier question about coming out of a turn, getting back upright is different, because the geometry is different. The front wheel can be steered in the proper direction to reduce the lean, so I expect there typically is more roll around the CG mixed in, unless you are able to accelerate out of the lean like on a motor cycle. Before you go "wait, how can coming out of the turn be different?", it most certainly is. A perfect example is in racing, where braking takes place
before the turn, but you accelerate
while still in the turn on the way out. Even tracks are shaped differently at the entrance and exit of a turn.
John
