safe said:
So on a recumbent you never want to push the bike too far because crash recovery is nearly impossible.
Cool, thanks for the treatise.
Yes, I can confirm crash/slide/wobble recovery is nearly impossible. Once bad stuff starts happening, I'm luckiest if I can put my feet down Flintstones style and come to a sane stop. I'm second luckiest if I can "ditch" the bike and I, still connected, to the right into grass or trees on the right of bike paths.
I have a problem (brakes/tire ?) at present that causes my rear tire to slide to the left with heavy braking. Only good thing is that this sets me up to ditch to the right, instead of to the left where traffic and joggers etc, are on bike path. So I keep my speeds relatively low on bike paths, particularly on areas that are dark, have bad or moist pavement or tight corners. I was wiping out occasionally on these paths before I electrified my bike. I suspect the added weight, speed capability and perhaps the handling changes with changed weight distribution are adding to my wipeouts now.
Anyway, the streets are where I saw some speed last night. I tested my 17 mile commute to work last night and was chasing cars and motorcycles at least up to 31+ MPH. Nice smooth roads with fewer curves and bumps than the scenic, but crappy for higher speed ebiking bike path. Now I understand better why Lycra usually prefers road to bike path.
The 25-31+ MPH road speeds seem safe, with good light and smooth straight roads. I brake well in advance though, and do curves pretty slowly to protect myself.
So: Recumbent: good for "tourist" runs, where you enjoy seeing the scenery without craning your neck. Good for seating comfort. Bad for low speed stability, climbing hills and recovering from "wobblies" or other wipeout inducers.
So what could a recumbent e-rider do to improve their handling ? Would shifting front weight higher and/or moving some back weight to front help handling ? The only weight I have to shift is my batteries (20 pounds, may increase to 27 when I go to 880 WH from 660 WH) and controller (1-2 pounds?). It seems silly almost, but if it would help to mount batts on some 1 foot vertical extension at the front end of my boom, I would seriously consider doing that.
Lately I've been pondering some "adult training wheels", that could be swung down and convert this 2 wheeler effectively into a 4 wheeler. Maybe a crazy idea, but worth some thought IMO. Wheels would be mounted on boom, or possibly on USS steering bar. (?) I guess this would need some suspension, or at least some give to take corners. (I'm assuming the wheels would be in constant surface contact, but they could also just provide a limit to slant like child training wheels.) This could give me low speed stability down to 0 MPH, and maybe help prevent many wipeouts. (??)
The laws here say you can't have more than 2 wheels on an e-bike. But perhaps non-contacting "training wheels" would stand up to a court test. I'm almost itching to be the first locally to get an e-bike speeding ticket, or something else less pedestrian than a mere stop sign running ticket. Haven't heard of an ebike ticket/court case yet in Ontario, since they passed the e-bike law two years ago. Maybe with a full fairing and 4 wheels they might take more notice.
