safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
The problem here is that it's really hard to tell what you mean. It's not your fault because we seem to lack a model that describes behavior well enough to be able to communicate well.SteveMush said:Lower center of mass should produce a more responsively handling bike, as the rider adjusts his mass-position to control the bike.
Low bike center of mass CAN be a good thing if the rider is also low. So a road racer type setup with a low seat and a rider stretched out in a tuck can do very well with a center of mass that is pretty low.
But if you were on a mountain bike and located your batteries low on the bike in a spot like behind the front wheel (or even attached to the front wheel like that one guy did) you are going to increase the INERTIA of your bike by a large amount. By increasing the roll inertia you inhibit the ability to get the roll started (countersteer) and also inhibit the ability to stop the rotation once you got it going. You would have created a very dangerous bike to ride.
"Seek Harmony and Balance" - The best handling bikes seek to create a harmonious balance between the rider position and the bike's balance. It's not about extremes... you don't gain anything by pursuing ideals of absolutes. The goal is to try to obtain the most perfect balance and harmony of bike and body.
...so this means that if things are stuck out on the ends of the bike that it's usually a mistake. Seek the center. (the hard part is to find the true center because it's often a mysterious thing)
The biggest problem ebikes have is that the "center" is not available because you need to pedal there. You want to place the batteries and motor into the frame (like the Optibike) but that's complicated so you seek the easiest and most pragmatic lessor option. You "make do" with less than ideal because you have no choice.
It's human nature to accept the "lessor option" and because of personal self esteem issues want to pretend it's something else, that you've found a magic alternative that defies tradition. But it's lie... you end up lying to yourself because the "traditional" center was right all along.
"Zen And The Art Of Motorcycle Maintenance" blended philosophy and design... kind of weird... but you might read it... :wink:
http://en.wikipedia.org/wiki/Zen_and_the_Art_of_Motorcycle_Maintenance
