Jonathan in Hiram said:
It would be a little more difficult and take a little longer to glue up shorter pieces of lamination into a bar, if I were going to do that I'd just overlap them a bit like the corners are done on the power transformers I've taken apart before. Sort of like a finger joint is used to join short pieces of stock in woodworking.
The laminations in a regular motor run parallel to the magnetic flux, do they not?
Or is it just that the winding core is short on most motors?
I'll try to be clearer in my explanation, it's a little tricky without a picture handy.
In a "normal" motor (i.e. radial flux), the stator core is made of a bunch of thin disks, insulated and stacked together. As the magnets spin around the stator, they see the narrow side of the laminations. The dimension that matters for eddy currents is one that is perpendicular to both the motion of the magnets and the magnetic field. On a more technical level, the EMF that causes eddy currents is defined by the cross product of velocity and magnetic flux, i.e. v x B. The right-hand rule applies here. If we're looking into a motor from the side, if the rotor is moving right-to-left and we assume the flux is flowing away from us, the EMF direction would be downward, parallel to the shaft. The stator laminations need to be thin and insulated in this dimension.
For an axial-flux motor, the eddy current-causing EMF ends up being in the radial direction (toward or away from the shaft). So, to minimize this, a laminated rotor has to be thin in the radial direction. The stators I've read about so far mostly seem to use spiral-would strips, like a clock spring.
If you're proposing what I think your proposing, I think the laminations would be in the wrong direction. What I think you mean is to take something like an E-core transformer, cut out the center bar of the 'E', then you'd have a 'U' shape like that in your drawings. Ideally you'd want the laminations perpendicular to the legs of the 'U', which would involve a lot of small pieces and be pretty annoying to build.
Of course the cores could be made of ferrite or magnetite bonded with resin of some sort.
I even thought of using toroidal cores with a section cut out to fit over the stator.
I think this would work out much better. Ferrite is non-conductive, so it can be solid and not worry about eddy currents. There might be some mechanical issues, but electrically/magnetically it should work well.
