teslanv
Great graphic, Teklektik.teklektik said:Great support teslanv!
Perhaps this might be helpful for some:
Mind if I borrow that?
Amps will affect torque and accelleration, but not unloaded speed.999zip999 said:Teklektik ( what does that stand for ?) So don't you need amps for that chart to work.
Sure - delighted to be able to assist.teslanv said:Mind if I borrow that?![]()
tech + eclectic999zip999 said:Teklektik ( what does that stand for ?)
What do you have? 3T? 4T? Group buy version or version 2.0? Thanks.teslanv said:If you are willing to pay the shipping, I would do a trade.arkmundi said:Is that an option? Thought I was stuck with the 5T. FYI, I haven't touched it - still in the box. Can trade down?teslanv said:The other option is to change to a different winding like a 4T, which has a higher Kv (9 RPM per Volt).
999zip999 said:So what's the reason for a 3t and 5t just to go slower. Yes yes I did read yours and justin posts. But wouldn't all motors be 3t which they said ( muxus ) posted .
I am not 100% sure if MXUS is able or willing to do the smaller spoke holes, but I will ask.arkmundi said:Can I get that unlaced but with the smaller 2.5mm spoke holes intended for 13/14 gauge spokes? I already have a rim, spokes and tire. Assuming same dimensions so my spoke calculation remains the same. Thanks. You're awesome.
Yeah, if you want high torque while keeping current low (Because you have a low-powered Controller and small wiring), then you would choose a Low Kv motor. You would do this with the understanding that top speed would be reduced, as compared to a higher Kv motor.John in CR said:999zip999 said:So what's the reason for a 3t and 5t just to go slower. Yes yes I did read yours and justin posts. But wouldn't all motors be 3t which they said ( muxus ) posted .
Primarily because MXUS believes the myth. There are reasonable reasons though for a slow wind if high power and speed aren't a priority, and they're mostly to be able to go cheap on the controller and wiring, not torque, heat, and efficiency. Plus it wasn't too many years ago that high current controllers weren't readily available, and lesser controllers fried while trying to push speed wind motors. The rapid growth in high powered scooters forced the Chinese to develop controllers to push those higher Kv speed wind motors, so controller availability isn't an issue.
Well, there is that...John in CR said:But then you might as well go with a smaller lighter motor too, because torque per amp is exactly the same for motors with the same Kv. The reason to go with a bigger motor is to get more power and speed.
I know the halls are right now. I had them wrong to start with. Reference post above. No way of measuring current draw without sticking the watt meter in the middle of the 24s pack, but I get virtually no voltage sag unloaded, so it can't be much. Controller does not get hot. I do have a spare 48V 30A controller I could hook up with a watt meter to test if it comes to that, but I'll have the tach by the end of the month. I'm in no hurry. Are there any markings on the motor that indicates the windings? if not, you may want to suggest they start doing that.teslanv said:I would wager that you either have a false positive Phase-Halls combo, or you accidentally ended up with a 6T winding.
What is your No Load Current?
And is your controller running HOT or COLD at 100% throttle?
wesnewell said:Are there any markings on the motor that indicates the windings?
999zip999 said:Teslanv I have tried and mapped all 36 combos. John so a 5t gets less hot and easier on controller and phase wires over a 4t ?
So you order 40 motors of various windings and there's no way of telling them apart without either taking them apart or putting them on a test rig to check rpm. With this being the case, I'm wondering how you separated the ones you got or even know if you got what you ordered? And how does the end user know what he got> A simple half penny paper sticker on the motor casing would take care of all this.teslanv said:MXUS marks the stator with the winding pattern.wesnewell said:Are there any markings on the motor that indicates the windings?
Actually I was very insistent that MXUS label clearly all of the various windings. (There were three different options.)wesnewell said:So you order 40 motors of various windings and there's no way of telling them apart without either taking them apart or putting them on a test rig to check rpm. With this being the case, I'm wondering how you separated the ones you got or even know if you got what you ordered? And how does the end user know what he got> A simple half penny paper sticker on the motor casing would take care of all this.
For all future orders I will be Kv Testing them before they go out. It's the only way to be sure.999zip999 said:Teslanv there wasn't blue tape on mine, maybe your China man took it off. Meaning a steel stamped motor from Muxus ? Let's not push them over the edge, but might be good for muxus in the end to mark there motors.
Ya - but checking the phase-to-phase resistance would be easier and would let you identify the turn count once you got the baseline resistances for each.teslanv said:For all future orders I will be Kv Testing them before they go out. It's the only way to be sure.
