chopper_elec
Hey mate, thanks for that. I was not sure the pinouts of the program relay but I wired it in the same way I used to with for lights, if i remember correctly I used it as a 4 pin relay, where the relay was powered with +which was controlled by the switch and - directly from the battery.
The relay was then used to provide a direct input from the battery which through the relay would be normally open, when the 12v was applied by completing the switch connection it would close the circuit. This way the switch wouldn't be taking the main load of the headlight, only to provide a small amount of 12v to power the relay
