IanFiTheDwarf
I think I will be pretty safe then, I hadn’t really thought about the gearing.
A lot of these type hubs apart from being a press fit do rely on the shaft end bolt to hold them together but some like this one are have a ring shrunk into a grove to hold them together. I think all bolt on rear hubs will be the same as there is no drive shaft to hold them together.
The ring marked by the red arrow is heated then dropper over the hub and shrinks as it cools into a grove. This hub can’t be disassembled without cutting or breaking this ring.
I will post an edited drawing showing the hub in two parts for clarity.
