John in CR
100 TW
I run a long custom swingarm on my Cannondale SuperV, 65cm (25.6") from the pivot point to axle. It's served as a way to get a longer wheelbase, which to me is critical for high speed. At first I built it to try different mid-mounted motors in the newly found space, but after getting hooked on very high powered hubbies I decided to securely attach some batteries there to see how they'd hold up. I can only fit a small shock due to the narrow space between the frame's seatpost supports, so it doesn't control the big weight on the end of a long arm very well on bumpy roads, but I stick to the smoothest streets. Low and rearward weight placement gives an ebike the most bike-like feel.
I'm wrapping up a swingarm modification to not only fit more batteries, but also get them closer to the pivot. I don't want to go much beyond the load I had on the suspension, so I started looking at weight. With regen I don't really need the motorcycle brake on the rear, especially now that I have the moto drum brake working properly up front. I got the food scale I picked up used (I wish it went to 20kg instead of just 10, but it was still a great buy) and did some weighing and measuring. Including the caliper mounting brackets, the bike brake will save a full 1.5kg . That doesn't seem like much in the big picture, but because the battery is much closer to the pivot, saving the 1.5kg very close to the axle will more than compensate for adding three 10s5ah packs of nanotechs to the swingarm.
The long and short of it is that changing the brake and moving the pack more forward will allow me to go from 20s11ah in the swingarm to 31s15ah but end up with a reduced effect of the unsprung weight on the suspension. I was kind of dreading the effect on handling of all these batteries I can now fit in the swingarm, so this was a pleasant surprise. Now I'm trying to figure out a way to fit another 4.5ah 31s string in there.
