izeman
1 GW
hi
i wanted to share my just finished 30min diy discharger project.
parts used:
some xt60 male/female plugs
some 14awg wire red/black
4 m4x15 screws
2 100w 6ohm resistors
one used artic copper cpu cooler (did fit a athlon cpu)
overview of the whole arrangement:
the two resistors where installed where normally the cpu is. put aside of each other, drilled 4 holes into the cooler, cut a thread, put some thermal grease on the surface and screwed the resistors down with the 4 screws.
then the resistors very soldered in parallel to get them down from 6ohm to 3.6ohm. unfortunately this is a bit too high. the correct value to use all 200w discharging power would have been 2.5ohm. then attached cables to put the resistor in line in the positive discharge wire.
this is the result. icharger 206b with resistor in-line. discharge power up to 150w ~ 7a
active cooling is a most (temp got >100°c). i took 13.8v from the power supply to feed the fan, as i think 25v is bit too much on the long run. or could that work? i was too much afraid to try for more than 2min.
now temp is >80°c
on the side you can't touch it for long, but you want hurt your fingers
let me know what you think
parts used:
4 m4x15 screws
Code:
P=U*I
200W = 25V * Amp
Amp = 8A
U=R*I
20V = Ohm * 8
Ohm = 2.5Ohm
now temp is >80°c
