Wishes
I've been using Li batteries for many years with my RC hobby and more recently with my e-bike. I am quite familiar with the technology. What I have never done is build my own battery pack with BMS. I have decided to take on this new project to help a neighbor. The elderly neighbor takes his mobility scooter up to his cottage, where it is all hills. So he is always climbing. It comes stock with 2 x 45 AH SLA's. But pulling a constant, or close to constant, 15 AMPs from SLA batteries, he is running them down in no time. The objective was to replace his sla's with lion or lipo. The application is a 2 x 25.9v, 32AH, 7 cell packs for a mobility scooter. They run on 24 volts, pulls 15 amps max. Hoping to give him 64AH of battery by connecting them in parallel.
I have sourced both a BMS and the cells for the application. I have a few good contacts with agents in china, and I managed to find these cells are a very reasonable price. Coming from the RC world, and even on my ebike where i use 6 cells 5AH turnigy packs in series and in parallel. I have never used such large single cells.
Anyone have any experience with these large prismatic cells?
Here are the specs of the cell I found.
Li-ion 3.7V 32Ah Prismatic cell
1 Model NO. SLPB60255255HR2
2 Original Japan
3 Material Li-ion
4 Nominal capacity 32Ah
5 Nominal Volt 3.7V
6 N.W 800g
7 Dimension for the cell body: 255x255x6mm
8 Dimension for the tabs 30x80mm
9 Dimension for the cell with tabs 285x255x6mm
10 Recommend Charge Rate 0.2-0.5C
11 Max. Charge Rate 1C
12 Recommend Continuous Discharge Rate 10C
13 Pulse Discharge Rate 20C
14 Working Charge Temp. 0~50°C
15 Working Discharge Temp. –20°C~50°C
16 Storage Temp. –20°C~50°C
17 Internal Resistance
≤1.5mΩ ( Tested with the 1000Hz
Battery Internal Resistance Tester)
Wishes
2 Original Japan
3 Material Li-ion
5 Nominal Volt 3.7V
6 N.W 800g
Wishes
