EcoForumZ
- Joined
- May 20, 2008
- Messages
- 83
My Stock Puma Motor Review
Test environment:
Name - The Widow Maker
Stock Puma hub motor
Stock 25a 36v controller
Shockley 36v 10ah LifePO4 battery pack
Beach Cruiser with 26" wheel
No peddling ever not even on take offs
Full throttle the entire time both up and down hill
The test road is 50% down hill 50% uphill
Top speed on level ground 22.3mph, avg speed on level ground 21mph
Totatal distance 23.4 Miles under the above stated test conditions
No loss in speed when going up hill or very little definitly less than 1mph difference
30+ mile range can easily be obtained with this motor and a 10ah LifePO4 battery pack. To obtain 30+ miles per full charge
you should use pedal assist when taking off from a stop, coast down hills, and use a small amount of peddle assist on flat surfaces and up hills. I
Will test this method later this week to see if I can get 30+ miles per charge without breaking a sweet or dipping below 20mph.
What I like about the Puma:
1. The Puma hub motor has more torque than any other crystalyte on the market including the crystalyte X5 series.
2. The Puma hub motor is almost completely silent. The sound of the tires on the road is about as loud as the motor itself.
3. The Puma hub motors freewheel spin has absolutely no drag so milage can be improved by coasting on flat surfaces and down hills.
4. The Puma hub motor has internal gears so the motor needs less amps to run but still has the most torque of any motor on the market.
5. The Puma hub motor weights about 10 pounds which is more than half the weight of a crystalyte X5 motor it's closest rival.
Youtube video - http://www.youtube.com/watch?v=AgZm48pYjBc
Test environment:
