wesnewell
And all that would be great if anyone gave a rats *ss. Doesn't change the fact that to find the rated max amperage of a 20C discharge rated battery is determined by 20 X AH. Which is wtf I said in the first place.
It has nothing to do with capacity....
Charge rate is often denoted as C or C-rate and signifies a charge or discharge rate equal to the capacity of a battery in one hour
I'd do the math, but I'm pre-occupied with my own matters lolwesnewell said:I guess you want to join the rank of those that want to confuse people.
Type c rate into google, then click on the MIT pdf and tell them they are wrong too.SamTexas said:I disagree with wesnewell. C is for capacity just like all others said. This is not a matter of opinion. It's well defined.
Well, I try to just enlighten people. Since you seem not to care about that, you can just remain benighted. If you change your mind, this will help.SamTexas said:I am not going to do that. But I will tell MIT or Stanford or CalTech ... that they are wrong when they are wrong. The title, the reputation of a person or an organization does not guarantee correctness all the time. I have seen smart, reputable people admitting being wrong all the time. That make them also respectable.
The C-rate (discharge rate) does not change at all regardless of the size of the battery.spinningmagnets said:Using a low C-rate chemistry in a very large pack improves the max amps that can be drawn from the pack, and also reduces the amps drawn from each cell. if it is technically correct to use the term "C-Rate" for both the individual cell chemistry and the fully assembled pack, I am confused...
I sense that you are getting more and more defensive. So this will be my last response to you on this subject. You can have the last word.wesnewell said:Well, I try to just enlighten people. Since you seem not to care about that, you can just remain benighted. If you change your mind, this will help.SamTexas said:I am not going to do that. But I will tell MIT or Stanford or CalTech ... that they are wrong when they are wrong. The title, the reputation of a person or an organization does not guarantee correctness all the time. I have seen smart, reputable people admitting being wrong all the time. That make them also respectable.
http://www.google.com/search?q=c+rate
C- and E- rates – In describing batteries, discharge current is often expressed as a C-rate
in order to normalize against battery capacity, which is often very different between
batteries. A C-rate is a measure of the rate at which a battery is discharged relative to its
maximum capacity. A 1C rate means that the discharge current will discharge the entire
battery in 1 hour. For a battery with a capacity of 100 Amp-hrs, this equates to a discharge
current of 100 Amps. A 5C rate for this battery would be 500 Amps, and a C/2 rate would
be 50 Amps. Similarly, an E-rate describes the discharge power. A 1E rate is the discharge
power to discharge the entire battery in 1 hour.
wesnewell said:I guess you want to join the rank of those that want to confuse people. OK, I have a 37V battery with a C rate of 20C, What;s the capacity of my battery. Get the point now?
spinningmagnets said:Since the C-rate is listed in the cell specs, and there's no listing for that chemistries C-rate per pack size, I was under the impression that it was the "Current" output ability per cell (I could be wrong, clearly I don't have a proper understanding of something here).
edit: some of my misunderstanding may stem from the well-known rule-of-thumb that drawing high amps from a pack will provide less capacity, while drawing low amps for a longer time will provide a higher capacity. The C-Rate of the chemistry doesn't change, but the capacity is conditional?
999zip999 said:Is this still a NCM vs lifepo4 thread. Or blow my trumpet thread. Get the train back on track. Why is this thread so frock up ?
