Hey Guys,
I need some advice/help on a bms system to suit what i have.
Its an electric motorcycle, 5kw hub motor, Sevcon Gen 4 Controller 72v-84v 140Amp cont/350Amp Burst.
The battery setup is 20s4p pack of LiPo's to give 72v / 64aH, Each pack is 72V / 16 aH. Batteries also rated 15C cont /30C Burst
Knowing the volatile nature of how LiPo's can be, i want some protection, mainly over charge / over discharge. balancing can be done externally but if done via BMS that would be a bonus.
I've looked at Zeva BMS etc.... however by the time i spend that much its worth more than the bike.
Anyone have any ideas of cheap alternative solutions ???
I looked at the chinese Bluetooth BMS and the only ones i can find that suit the 140A cont of the controller are the 150A(some 300A ones also) for approx $150-$200 each, which is fine but it will only do one pack and when you need 4 it all adds up.
Ideal world i'd run different batteries and such, but im just trying to get along with what i have and to run it safely.
Any help would be great.
