Hi, I'm building an overhead cable car (not sure what to call it) and I need some advice on what motor/controller/battery combination to use. I hope I put this post in the right section.
There will be a wire going through my woods, supported at regular intervals by a bracket attached to the side of trees. There will be a seat to sit on and an electric motor which will be capable of going either forward or reverse.
Here is a video of the early progress I've made:
https://www.youtube.com/watch?v=Er6zJBmLhlc
Basically there will be two caster wheels to hold the weight, and a third wheel in the middle which will be powered. The powered wheel will be pneumatic so that it has better contact with the wire. It will also be on a lever, so I can engage/disengage it from the wire.
My problem is I have no idea what size motor I need. I figure it will weigh about 300-350 lbs including me. I'm guessing I need a 500w 48v motor, but would that be too much power? I don't want to go super fast, I just want it to go maybe 5-10mph with no problem.
Any insight is greatly appreciated, thanks.
Chuck
Chuck
