Hello everyone! First time poster here. I have never built an ebike before and I have been looking to convert my old bike that I haven't used for a while into an electric bike. I was primarily looking at the Bafang BBS02 mid drive motor from lunacycle. With the motor and the battery (48v 11.5ah Panasonic cells) it comes down to about $1,100. I had been researching about the BBS02, it's benefits and drawbacks.
But I wanted to get some second thoughts from everyone else who has experience with this.
What I'm looking for:
Desired max speed on level ground: 20mph (Legal speed limit)
Desired max range: 52 miles going at 15-20mph. (I will be using this to commute to and from work. It will be 26 miles to get there and I can charge it while I'm there but if possible I'd like it to be round trip but no big deal)
Preferred bike: Since I am converting my old bike which is a Raleigh Detour 3.5 (I don't know what year model and it's been hard to find any specifics online) the wheels are 700c I believe.
Brake type: I would prefer disc brakes but for now I will keep it as a normal V brakes.
Rider weight: ~162 lbs.
Terrain: Mostly flat, urban environment, city commuting with some small hills here and there.
Budget: For right now it will be $1100 or less. Can upgrade smaller parts in the future.
Extra info:
I do currently own a factory built ebike right now. The one I have is the http://www.walmart.com/ip/Cyclamati...-Mountain-Bike-Lithium-Battery-Black/44664817 The reasons I am wanting to upgrade is for several reasons.
1.) The ebike I currently own seems slightly underpowered.
2.) I would like to build my own ebike for the fun and learning experience.
3.) With the BBS02 I think I can reduce the overall weight of the bike.
4.) Changing flats will be MUCH easier if I go with the BBS02 compared to the rear hub on my current one.
5.) UI systems are much nicer than current one. (Battery indicator, UI display, etc.)
6.) Current ebike is a little longer than I would like it to be and doesn't fit me quite comfortable as compared to my normal bike that I plan on converting.
7.) Current bike on throttle only can only go about 14-16 miles before battery dying. I would like something that can go longer and have it easy to find a replacement or spare if needed. (Current ebike's battery is difficult to find from a reputable seller)
Some concerns I have with converting my own ebike:
1.) Not TOO sure if battery pack will fit my frame. I'm like 80% sure it can fit if I use a different type of battery packs offered at Lunacycle (i.e. Shark battery, Dolphin battery, Bottle battery, etc)
2.) It has been a while since I've use my old bike, never has been FULLY tuned up from a bike shop. But I might take it prior to converting to have a overhaul done to it at my local bike shop.
3.) Not 100% sure if bottom bracket is compatible with the BBS02.
4.) Couldn't find any information as to whether or not the connections to the battery and motor are waterproof and plug&play? Or if I would require soldering skills and all that.
Pictures of by bike that I plan on converting:
http://imgur.com/a/BrU9D Would love to know if anybody can tell me if any of the batteries (Shark, dolphin, bottle) will fit here? I tried to measure it on paper but I didn't know at what angle the Shark and dolphin packs were curving at.
My choice has come down to the Bafang BBS02 750W with a 48V 11.5ah Panasonic Shark or Bottle battery from lunacycle.com. But would love to know any feedback on if there are other, better, solutions?
Thank you all in advanced for helping me!
Extra info:
