flexy
My charger is a 10A 87.6V version, model KP7210BL ,from EVassemble.
I need to adjust the charging voltage above 87.6V so the BMS takes over the charge cutoff
This is a view of the inside;
The only things I can identify as pots, are the blue, square ones with a small brass screw on the top. They are all bunched at the output end, underneath the display panel. Does anyone know which one I need to tweak to raise the voltage?
