Man Daly BMS is junk when it comes to the programmable version compared to ANT BMS.
So since their support barely understands the English language and just repeat my question or answer with a typical 'yes', so here I am asking you guys.
So, attached are the two screens I ran into some wandering about some of the settings in them:
diff Temp protect - does that mean that when a temperature gap larger than this setting is crossed then it cuts off? it's one thermistor, it doesn't make sense!
Sleep waiting time - now I'm used to ANT BMS where 'sleep' means that the blutooth is being turned off and that setting in ANT is 180 seconds by default and here in Daly land it's set by default to 3600 seconds (meaning one hour) which seems like alot
Also, I ran into zero explaining on how it turns on for bluetooth connectivity...
Does a charger do it? discharging for a moment like in the ANT BMS? does it turn off after 3600 seconds and sleep means blutooth sleep?
Such stupid programming, I have to input the password for seeing the different cell voltages!
I mean, I need to hand it to a customer who requested the app option but I don't want him to change the max current settings or any setting so instead of being locked I have to give him the password in order for him to see all the data.
and if that's not enough, I tried hitting the max current setting, the BMS cut power like it should but now if I want to turn the power back on I need to tell the customer to either go home and stick it in a charger OR, of course, give him the damn password so he can reset the BMS through the app.
Who knows if I need to do this hard reset every time ANY of the limitations are crossed.
Why on earth people are so stupid in Daly company, so so stupid!
