VapingMonky
100 µW
- Joined
- Nov 27, 2015
- Messages
- 8
I'm currently running a 48 volt thousand watt rear hub motor on my giant iguana mountain bike, I'm using 4 led batteries currently, and I'm in the middle of filtering through laptop batteries my question is what would be a good power supply to help me speed up the process of charging multiple batteries I purchased 18 650 holders to wire them in parallel is there any cheap circuitry I could find on eBay or elsewhere to attach so that I could set a voltage cutoff and what would one recommend for a ( power supply) that I could use to charge single 18650's and eventually a 48 volt lithium battery when it's complete if this makes things complicated then a 24 volt power supply would be fine as I could break the 48 volt pack into two sections for charging in the meantime
I work 8 to 5 Monday through Friday and have a little daughter so I haven't much time to scan all the forms so I figured I'd ask here I just want to find an affordable power supply that's flexible and consume the needs of a DIY lithium pack builder I have no problems buying a voltage meter in battery holders that's all cheap stuff just want something affordable and solid that I can adjust amps and voltage or at least the voltage as low as 3 volts
Sorry for the poor grammar thanks in advance
