drewjet
I again cannot type what I am thinking. I read a few pages back that 4.2 volt was possible. What I meant was, is there a total pack voltage limitation, could the system used on a 700 volt battery?
drewjet said:I again cannot type what I am thinking. I read a few pages back that 4.2 volt was possible. What I meant was, is there a total pack voltage limitation, could the system used on a 700 volt battery?
recumbent said:Nice work![]()
Are those LED's that i see in the picture?
Does one light-up when one cell is not performing like it should?
What would be (roughly speaking) the cost for a kit, to attach to 16 Lifebatt's/48 volts?
I'm all fired-up to see these available for the summer of 2008.
GGoodrum said:recumbent said:Nice work![]()
The orange LEDs are used during charging. When the cells start getting full, they start coming on. When fully lit, the shunt for that cell is in full bypass, so the cell is full. When all channels are in full bypass, the charge current is cutoff, the orange LEDS all go off, and the green LED is lit.
-- Gary
i'm not sure what you are talking about? you posted a link to a fast high current diode that has way too much forward drop to use for sharing battery packs. the 40CPQ100 diode i typically use is 100v 40A and has about .55v forward drop which is 1/3 that of the diodes you suggested.Deepkimchi said:Whoops - reckon my question about the diode connection was off topic - never got an answer.
Maybe Bob's applying for a patent :lol:
Deepkimchi said:Nah - that's why I thought I was off topic. The question wasn't about your BMS.
I couldn't figure out whether the diode was placed across the battery poles the same polarity or reverse polarity. It's an outstanding idea from you, I just don't dabble enough to be sure about the hookup.
The other question - I'm sitting on $ 600 worth of a 36V 12 ah pack, if I used your individual LVC, could I attach a different format and AH pack (ie 6 cells of 10ah - 40138) in series to my existing pack?
Would have 2 packs in series each with your LVC and diode setup, so I wouldn't have to worry about the controller LVC.
DK
Patrick said:Hi Gary and Bob:
If I wanted to use the BMS on a 72 volt pack, of course I would two of them; with one jumpered (and perhaps less populated). Would I also need to use two chargers (either isolated, or break the series connection between packs)? I was assuming I would, but then thinking about it it wasn't obvious.
Where are you at in terms of production?
Thanks for such great work!
GGoodrum said:Actually, the building of the boards is not all that difficult, but unless you are a trained assembler, it can take quite a bit of time, as there are 284 parts. I am not a trained assembler, so until I can find a place to have these put together for a reasonable cost, I think it will have to be kits-only, for now. Who knows, maybe someone here will want to make a little extra money, and provide an assembly service.In any case, Bob and I are doing a detailed set of instructions, with lots of pictures,for assembly, testing and for making the proper adjustments. I hope to have the first kits available early next week.
-- Gary
recumbent said:Okay, enough teasing us with these awsome looking boards,do we just place the components in the proper holes and solder them in place?
I have a large magnifier with light attached to my work station, fine solder wire, and tweezers, do we need anything else besides the iron & a steady hand?
