EMF said:Yep, that there scheematic looks right to me! :wink: j/k
Wow! I cannot believe what you guys are able to come up with. This is very impressive indeed. It's way over my head, but still, I can be impressed by it.
I think you guys should take your wives out to dinner and a glass or two of wine since you are tinkering too much!![]()
jeffkay said:What I meant was this: The cutoff voltage is say 2.7 or 2.5v. After the BMS/CMS device does its cutoff, if the load is removed, the cells should be at some voltage of rest--what is that? It is probably in a range of 3.00v?
I have charged the 12p sub-packs in under 20 minutes using my 80 amp Vicor supply! Yes the charge wires (6ga.) get hot!!!
Jeff K./ D"Deep Cycle"
"Serious watt hours"... Yes, "Deep Cycle" is a full size commuter motorcycle conversion. Originally a 1973 Yamaha 750cc, it uses a first gen Etek and an Alltrax set for 150 amps. I have been reconfiguring the packs and now have 4 packs with 4 sub-packs of 16s12p. I drove the heavy bike and heavy rider (!) the other day with 3 packs (36v nominal) and it went over 14 miles on very hilly route. It is geared to be about 7:1. The 4 pack estimate should get me 19.5 miles or more on the flat. Speeds with that pack have reached 50mph but realism dictates about 40-45mph. It is a blast.
Deepkimchi said:Hello Bob,
What kind of sleep problems are you having? Remember Xyster seemed to have it too.
My brother swears by Melatonin. I try to think about ebikes when I have trouble sleeping. I'm almost 51, and have PTSD from something I can't talk about (things that went boom). A shot of Cognac helps too about 1/2 hr before bed. Working out at the gym helps relieve stress. Going to bed at a fixed time, not doing anything else but sleeping in bed (besides that other thing), watching caffeine intake such as coffee/sodas (avoid late afternoons), may be some things that help.
DK (an American in S Korea, not Paris) :wink:
the shunts can only handle 8A , but when the shunts activate the charge current is reduced, so the shunts do not have to carry all the current, the lvc circuit does if it is used, and if the charger has the proper output voltage of 3.65v per cell plus a half volt or so for fudge factor, and not so much that there is excessive voltage across the fet that limits the charge current. we really do not intend the system to handle that high current, but it is possible since the high current only goes through the cells if the low voltage disconnect function is omitted and the ebrake signal used instead. even at 20A the dissipation in the fets would be just a watt or two, but the pcb traces are not intended to carry that much current. beefing them up with extra solder would probably make it possible to run at 20A but we have to draw the line somewhere for warranty purposes.rarebear said:Hello Bob and Gary!!
Congratulations !!!!!!!!!!!!! very impressive!
My question: (12 cells LiFeBatt)
Is the LVC realy needed when i set my programmable controller to a safety LVC (28V?)
depends on whether your cells stay balanced. i feel it is cheap insurance on expensive cells to watch each one or each parallel group
I would like to use your:
"Charger Management System (CMS) as an external board/unit that would sit between the output of a standard SLA charger, or a regulated power supply, and the pack, connected to the latter via a special 18-pin plug."
Is your 12 Cell CMS (external board) also available? or only the BMS board with LVC?you can use this system that way just with longer wires and an 18 pin molex connector which i believe gary hasyou would have to use the complete board and just not stuff the lvc parts
I will use two of yours LifeBatt 12 Cells Packs in a high speed application (wired in series)
and in a long range application (wired parallel)
I also want to quickcharge it with a 20 amps output SLA charger. (Is it possible?)
fechter said:You're obviously on the right track there Bob. You have something that actually works and way out performs any of the other commercially available BMS circuits I've seen (mostly RC stuff).
Sure, there will always be room for improvement with any design, but it's important to do actual testing and observe the behavior before you can refine things. Your observations in the difference in charging time vs. shunt current, for example, are good lessons. Not everybody wants the same thing either. I can buy a "duct tape" BMS from Ping for $43 plus shipping from China, but that's not really what I want. /quote]
thanks fechter, it means a lot coming from a working fellow engineer. the circuit could be described as firing a shotgun at a bluebird, but the argument is that if you really want to hit it a shotgun is a better choice...I built one of the Popular Electronics Altair 8080 home computers in '65 that you programmed with switches and graduated to a paper tape 6800 then pdp 8 to 11/20 to 11/34 to vax 11/780 then to CRAY, then followed the stairway back down to reduced instruction set (RISC) and PIC (programmed instruction control - a Microchip trademark) chips that perform functions we only dreamed of when we built the first MRI machine powered by a 6802. You can do a lot these days with a PIC but the code still has to be written by a human. With this all-analog design if you want to change the time that the cells are held at the peak voltage you just change a resistor or cap, and if you want to get a bit of extra runtime out of your cells by charging them up to 4.00 instead of 3.65v or maybe get some extra service live by charging them just to 3.55v, you can achieve either with a simple pot adjustment.
instead of going in to the software to vary the current during the final phase of the charge cycle a pot is provided to adjust it from a few hundred ma to a couple of amps. Each individual user has the ability to tailor the system to suit their needs. Of course to maintain warranty the values must be set to the factory recommended levels.
if people just want partial function they can just not stuff some of the parts. I agree that a patent is only worth what you are willing to spend to defend it, so i did not even consider the idea. i really doubt there is anything worth patenting in the design, and i would not want to contribute to the idea that there was. Gary and i did spend a fair amount of time assuring that the design works as intended, and we are still today finishing up the procedure for test/assembly for users who want to buy kits.
i heartily recommend the kit as a way to gain a better understanding of what the bms does, what your battery does, and how to assure the maximum service life from your battery. We are finishing up the procedure today, Gary of course doing most of the work while i sit here with a bloody mary and help him through the magic of satellite technology ;') don't get jealous quite yet, i expect to see some profit from this endeavor just about, uh, never.... but it is a fun and interesting way to keep busy.
OneEye said:The variable power supply is used to set the trim-pots and refine the maximum charging voltage for each cell. You could calibrate it with a battery and a voltmeter, but it might take a lot longer to make sure you have it set correctly.
PJD said:I brought this issue up already in an e-mail to Bob, but I thought I'd bring this up with the community for ideas.
My e-max scooters, and I suspect most street-legal equipped electric scooters and motorcycles, use the +12 volts from the tail light circuit to signal the controller brake cutoff. They also have +48 or +60V logic circuit power wire which is turned on through the key switch which could be used to cut the controller off.
But, the BMS's LVC logic is a "low" for cutoff and "high" for on - or just the opposite of what is needed. (although I'm curious if +12V is actually needed, maybe a +5V logic signal will work too - I should test it)
And simple ideas how to address this? Yes, I could connect the contactor relay negative (rather than the 95 amp pack circuit negative) to the cutoff FETs. But in a LVC condition the relays will be cycling on-off-on under high amp load which they aren't designed to do.
