FINALLY !!!!!!
Thank you so much Justin! With the addition of torque-throttle and fully detailed custom-motor option, your Motor-Simulator is truly up to date!
It seems you are eventually following (almost) all our suggestions.
I know I sound "greedy" when saying this at this moment of joy, but one thing I would like to see in your Simulators is the ability to simulate the conditions during field weakening.
If the analytical model is too difficult or unachievable (at the moment), it's possible to do this discretely by testing the unloaded speeds of different motors at (for the sake of the example) 5A, 10A, 20A, 30A of field weakening currents and so on, and record the weakened kV on each. (by the unloaded speed)
Then, a user, which chooses such tested motor, will have the option to choose those respective tested field weakening currents. In each setting, the kV of the motor would be adjusted according to the respective unloaded test (ONLY if the motor runs above it's normal unloaded speed and/or the demanded phase current is higher than what the back-EMF allows which requires weakening)
Am I understanding this all correctly?
I've yet found an article or a way to understand how does the field weakening current vs delta-kV works...
If what I suggested above is logical, I would be happy to test this for all the different motors I currently own, and send you the data so you can include it in the simulator.
And again, Great job with the Simulator
