Motor controller with variable regenerative braking
Teh Stork
Hi,
We are going to build 3 test benches for mid drive motors. My question is related to controllers with regen capabillity.
I have used controllers from Sabvoton, Kelly and TIs Instaspin FOC development boards - most have been a simple coasting regen, where the instaspin board did full variable regen.
The testing is automated using a microcontroller controlling everything, 1 battery feeding the test bench and 3 motors with separate motor controllers. 1 motor emulating the human input, 1 motor under test and 1 motor for regeneratively braking the motor under test and motor emulating the human.
Pass/fail testing is based on efficiency measurement, temperature check after extended riding and noise level.
Currently I am researching what motorcontrollers to go for. The motors used are around 1 kW at a bus voltage of 36 V. Originally I was planning external power meters - but researching the problem more maybe this measurement can be internal to the motor controllers.
Where is time researching/programming best spent? Is the VESC project the best bet - or are there simple china controllers of fair quality that will do variable regen like BMSbattery Kunteng controllers?
Appreciate any input,
It is basically going to be throttle or regen, yes - no coasting. Motor 1 will activate torque sensor in Motor under test (motor 2), and Motor 3 will act as a generator. Motor 3 will get the whole brunt of Motor 1 and 2.
Could do a simple 3-ph rectifier on the generator, making sure that the voltage generation would be higher than the battery voltage through gearing - but this would make for a very fixed setup with regards to what loads and rpms can be tested.
Grin products are quite pricy for what they are. I would rather have a go at VESC if allowing that kind of budget for the controllers.
VESC and the Phaserunner / Baserunner all do variable regen. AFAIK they can be controlled from the throttle or a separate variable input. Since the *runner are based on ASI, then those do it too, but ASI is much more of a PITA to setup than the Grin stuff, because Grin wrote their own good setup software for it. :)
