tomjasz
1 GW
opperpanter said:The kits I got from Paul/em3ev came was the C965A display. This display can have maximum speed limit set to 99.9km/h.
Will post manual later.
And C965 pinouts
mwkeefer said:The software is actually easy to use but designed for the BBS01 - don't have one any more to check controller model and revision, may be the same as in the BBS02. I've got an open source version which will be coming soon and will hopefully be simpler to understand.
The curves would look the same until the point where the 17 A limit is reached, which you can see when the cyan curve levels off, at about 70 Nm. Beyond this, a higher current limit would result in the following:Warren said:"Since the max amp draw is around 17-18 Amps, I guess this is the 500W version? How would the data/curve look for 750W?'
It would look exactly the same.
Fixed. Torque continues to increase as RPM decreases (unless the controller limits phase current, in which case it levels off at lower RPM).About 80% of no load speed is most efficient, about 50% of no load is most [strike]torque[/strike] power.
That was a while ago; since then he's ditched the Bafang controller entirely and has been running the drive with external controllers. Search his posts for details.crazypick said:Hi Mike, any news on your open source controller config project?mwkeefer said:I've got an open source version which will be coming soon and will hopefully be simpler to understand.
Depending on the programming, the cadence may be limited in the software. Try different PAS levels and see if this cadence limit changes.opperpanter said:With the 44T x 11T gearing, this is about 80-90rpm.
I was expecting the BBS02 to go all the way to ~110rpm?
The kits from em3ev are (supposed to be) programmed with 100% throttle in all PAS levels.cycborg said:Depending on the programming, the cadence may be limited in the software. Try different PAS levels and see if this cadence limit changes.opperpanter said:With the 44T x 11T gearing, this is about 80-90rpm.
Thanks.cycborg said:The curves would look the same until the point where the 17 A limit is reached, which you can see when the cyan curve levels off, at about 70 Nm. Beyond this, a higher current limit would result in the following:Warren said:"Since the max amp draw is around 17-18 Amps, I guess this is the 500W version? How would the data/curve look for 750W?'
Battery current (cyan) would level off at 25 A, at about 25*70/17 = 100 Nm
Input power (brown) would level off at 25*48 = 1200 W at 100 Nm
RPM (red) would fall off less quickly between 70-100 Nm, then more quickly beyond this
Output power (blue) would continue to increase, reach a maximum probably somewhere around 100Nm at a level of 700-750 W, then decrease.
Efficiency (magenta) would probably look about the same, just continuing to decrease
To who is your reply addressed? I just talked about *downgrading* my unit to 500Watt in the exact same way cell_man does.tomjasz said:Careful, if you bought from Cell_Man. He's had it with experimenters trashing their controllers and crying insisting on new controllers. Unless you clearly understand the complexities and the potential problem with playing at settings I suggest you leave it alone. BTW he IS a member and does read threads. We've communicated about a couple of them. A set of parameters coded by someone you doesn't have a drive hardly seems a sensible solution. Frankly I'd get the settings that EM3ev used and simply replicate those. The most recent are some of the best by most reports. The BBS02 is no hot rod to be punched up by experimenting, at least no one has shown a reliable path that is much of an improvement of EM3ev settings. Hell Paul even managed to make some early errors and had to eat some controllers.
I looked at some settings by some of the brighter engineering types hanging here. Take a look at some of the settings Kepler used for some safe guidance. The BBS0xis a great reliable drive, but it's not a tinkerers drive with room for much improvement. Problems with asshats messing with unknown settings has already shut down access to controllers by EM3ev non customers. Whiners trashing while programming and then whimpering warranty. Nutless twerps ruined a good source.
John Bozi said:how many of you banfangers have broken chains and how many times?
Im over a few. note I havent got a very good chain line to granny
Ade said:John Bozi said:how many of you banfangers have broken chains and how many times?
I mangled a link within the first 3 weeks - I think it had more to do with indiscriminate shifting under load more than anything. My chainline is off by quite some so I'm limited to the 6 highest sprockets or so as well; most of the time it stays in the smallest 3. I've ordered a new hardened kmc e-bike chain, a new steel sprocket set, and a custom 42t chainring which will bring the chainline back in to where it should be, all of which should help with chain slips, chain drops and broken links.
Ade said:and a custom 42t chainring which will bring the chainline back in to where it should be, all of which should help with chain slips, chain drops and broken links.
Aushiker said:Ade said:and a custom 42t chainring which will bring the chainline back in to where it should be, all of which should help with chain slips, chain drops and broken links.
I also have a chainline issue so I am interested in your custom option. Do you have a link by any chance?
Thanks
Andrew
No 38T?????? pity. Its far better suited for the 250W Bafang on City Bikes with 8 speed Nexus hubs.Ade said:http://em3ev.com/store/index.php?route=product/product&path=46&product_id=197Aushiker said:I also have a chainline issue so I am interested in your custom option. Do you have a link by any chance?ThanksAndrewAde said:and a custom 42t chainring which will bring the chainline back in to where it should be, all of which should help with chain slips, chain drops and broken links.
Ade said:Aushiker said:Ade said:and a custom 42t chainring which will bring the chainline back in to where it should be, all of which should help with chain slips, chain drops and broken links.
Thanks
Andrew
leelorr said:California E-bikes sells two sizes of chain ring adapters for the BBS0x. You can see them both at :
http://california-ebike.com/product-category/replacement-parts/
