Geebee
They are gorgeous, I love the relaxed geometry much more rider friendly.
They truly don't make them like they used to.Geebee said:They are gorgeous, I love the relaxed geometry much more rider friendly.![]()
rodgah said:interesting, I had not counted the speed of gear change an issue but I haven't ridden a multispeed mid drive yet either. The thing that gets me is I can go for a ride on my HT bike and go 30kms on 160whs (considerable pedaling) and never feel overly exerted, yet if I ride a pure pedal bike I feel like am going beyond my limit in a few minutes and I couldnt imagine going 30kms. Most of my riding in the bush is coasting downhill and powering/pedaling back up, something I definitely wouldnt be able to do under my own power alone....maybe I need to loose the weight and try one of these. What would be your thoughts on trying this on a freeride/dh bike?
Kepler said:Yes, and thank god for that![]()
. Just kidding. I am sure vintage has its market.
Greenspark, that is a fair investment in drives. Did you get any of the 750W versions for those who are looking for a bit more power?
Kepler said:Wow, 160whrs and 30km out of a HT. Now that is economy.
The drive would work on a freeride/dh bike and was my plan for a while. Ended up deciding against it though going back to an XC setup because I found I was doing a lot of pedaling on my test bike when using it off road. Also, it was very hard finding a DH/freeride frame that had a 68mm bottom bracket and rear suspension that cleared the drives final output gear cover and 48mm chain ring. I was willing to go down to a smaller chainring, but the 750W unit suits the bigger chain ring best.
jk1 said:Their has been comments about how the power and speed of the bafang 350 and 750w kit seems to be less them people have expected for the wattage, i.e compared to hub motors and other midrives. Could this be to do with the low efficiency of the muli stage helical gear reduction system discussed here ?
http://endless-sphere.com/forums/viewtopic.php?f=2&t=56903
i.e it shows up as a lot of watts consumption, but the actual output power at the wheels is a lot less and hence slower speeds then people think it should be per watts ?
rodgah said:Kepler said:Wow, 160whrs and 30km out of a HT. Now that is economy.
like I said....considerable pedaling and slow speeds :lol:. I assumed this drive fitted on a 73mm BB too? It is not easy to find a suitable frame....especially newer than about 06. Frames like Transition Blindside, blur the lines between FR and all-mountain....which realistically is what I ride. Still has an ISCG mount to grind down, but at a guess would have the chainstay clearance needed since it can be setup as 2sp front.
In some respects a 29er is very suitable so you dont have to use such a large chain ring....or a 11t cassette for that matter either. Decisions decisions
Has anyone paired the Bafang with Shimano 2014 Alfine 8?
Any problems shifting under load or high speed?
Kepler said:Thought it was interesting to see that this drive has been used on the new Caterham concept carbon ebike http://www.flickr.com/photos/caterhambikes/sets
