This is way off topic for Bafang drives, but in general you shouldn't mix SRAM and shimano shifters - at least on mountain bike components. Road I have NFI. The pull on the MTB shifters is different between SRAM and Shimano. And things have become more complicated of late. You would generally be better off with a shimano shifter for the Zee.Craig F said:Thanks Guys .....I think I will go with the Shimano M640 Zee Rear Derailleur..It sounds specific to my application,,I assume it would be ok to use with a SRAM 10 speed shifter.???..http://www.chainreactioncycles.com/au/en/shimano-zee-m640-shadow-10-speed-rear-mech/rp-prod82431
Having said that, there are some that are having success with what is referred to as SRAMano - SRAM shifters with Shimano clutched derailleurs. Some links: pinkbike, rotorburn, singletrack. Unless you enjoy tuning derailleurs and already have a SRAM shifter you want to use, I would be going for a Shimano shifter.
I actually have a nice SRAM X-9 shifter and like fiddling, so I've got a Zee 36 showing up shortly to see if it works. Clutched goodness for cheap. I hope!
