ebikedelight
- Joined
- Dec 25, 2014
- Messages
- 307
gridlok said:Yes the Dolomite might be the perfect cheap donor bike. I'll be posting another build thread in the next week or two for our conversion.
Bikes direct bikes are very goos as well and much lighter. I just bought a deadeye monster single speed ($300 which is $100 off because it was banged up from shipping) that I weighed last night at 31 lbs! Brakes are crap but the drive train is steel and looks usable aluminum frame and the beefiest rear dropouts I've ever seen on an aluminum frame.
Karl
At only 31 lbs, that is impressive for the low cost ...but I wouldnt like just 1 speed on a fat bike.
FWIW....It isnt to hard or expensive to get the dolomite to around 40 lbs . Just by replacing stock tires and tubes , with a 120 TPI VEE mission tires and Q-tubes super light tubes , you can drop the weight by around 6 lbs . I bought a new set of VEE tires off craigslist for $60 and the Q -tubes on ebay for $24 . So for $84 , I easily lowered the weight of the dolomite .
Id also like to mention the importance of pre=checks/ lubes on these fat bikes , ecspecially the big box styles walmart bikes. My dolomite had axle bearings in the wheels and bottom bracket, that were bone dry of grease, and way overtightened . If I had rode it the way it was, the resistance woulda been much worse and the bearings woulda worn down much quicker.
