Sorry... I dont know what to tell you boys, I just cracked one of these open in 3 minutes flat :lol:
Did it right here in my office chair with noth'n special
You have to have just the right bit... this one kicks ass.
I start wedging it open with a tiny, tiny flat head if I care about the finish... but..... why would I care about the finish?
These work fine
I steered you wrong a bit in the last post. You actually want to start with the wires DOWN, remove all the fasteners on the opposite side, then when you pop it out you gain access to the wire side.
Anyhow....
Before popping out the wire side I cleaned out all the silicone. That stuff is really bonded to the black sleeve (which is just for aesthetics you understand... the toughness is in the woven cover). I tore the black one a little bit while clearing out the goop, but it makes no difference.
NOTE: IF you attempt to remove the covers without first removing the silicone you WILL scrape the wires on the way out... I suspect some people may actually be causing the damage during dis-assembly
Anyhow - my batch of motors do not have the cut wire issue
The wire sleeve does not even have so much as a nick in it
My axle is machined down about 4mm.... how deep is the grove on the motors you guys have?
And of course the stator is 35mm and halls are installed
I get it that you early adopters got burned.... I did too.... but just look at this motor. Anybody who has been in this game for a while KNOWS that the quality here is AWESOME. Dont mix up early production issues with quality issues. Everything about this motor rocks - even the rim is wider. I am SUPER STOKED right now
This one is going on my trike :wink:
-methods
