ohzee
Personally I am think a deep forest green , but yea I like green.. The neon type green also looks very sharp.
Rodney64 said:Anyone interested in starting a discussion thread for phasor, I'm happy to kick it off
korpin said:one of those white frames is probably mines..HPC doing electronics around 100 volts 4500-5000 watts with boxxer world cup forks using the newest lightest batteries
Rodney64 said:Ok Deutch that's good, share, discuss & components used sounds good. I'm frame 6 so still away off. Would be good to have someone from the first 3 to start it off.
ohzee said:I was told mine was 4th so hopefully your fifth
Anyway it looks like frames are close to shipping an exciting time.
ohzee said:http://www.primo-powder.com/pdf/durable.pdf
http://www.primo-powder.com/pdf/cardinal.pdf
http://www.primo-powder.com/pdf/ral-colors.pdf
Those are the color charts David gave to me.
ohzee said:korpin said:one of those white frames is probably mines..HPC doing electronics around 100 volts 4500-5000 watts with boxxer world cup forks using the newest lightest batteries
Thought I found out who had the 2nd frame , but after going back and reviewing your just repeating yourselfNBD Id be doing the same if I was getting one so soon.
Can not wait for the reviews.
Rodney64 said:Deutch the 3 speed switch you were talking about are you making it yourself or did you buy it.
korpin said:hey by Deutch420,are you gonna have any air cooling on that 10,500 watts?....wow the bomber is only 4500 watts on the specs,but I do not know the true voltage times amps on the bomber do you?
not sure about the 8 gauge wire but according to the electricians chart,if you are intermimittent rating of maxinum 2 minutes then its fine but 6 would be needed for a longer duration of 80 amps and over 115 volts for over 2 minutes but its close
and any idea on what kinda weight you will be at?
korpin said:I have seen quite a few u tube videos where guys are using high wattage and getting 58 to 60 MPH something but the bomber is getting 48-50 MPH at half the wattage some of these guys are using which makes me think stealth is lowballing the power specs
