New guy with baserunner 'Current scaling' fault
CazBilly
10 µW
Hi Guys,
I guess I Need help setting up my new baserunner. I got my wife a cheap chinese fat tire bike back in the summer and it has never had much power. Its a Nakto 36v 300w hub motor
my new standalone baserunner/CA3 arrived yesterday and ran autotune with 23 pole pairs ( a WAG from a youtube video fo a similar bike) and 15v per rev.
It ran autotune fine and seemed to be running great. Set iself to 17.96RPM/V and 23 pole pairs seemed to work. I was jazzed to test out since it seemed to have lots of power
This morning I decided to check everything on the baserunner suite basic page before putting it all back together and I turned down the motorpower to 550w as this is an basically unknown hub motor (300w 36v altho now 48v).
Now I have a fault: Faults2[1]: Current Scaling
So then, I reset the CA3 to defaults but no luck. Still Current Scaling Fault
On the 'Basic Setup' tab of the phaserunner suite, under the heading: 'Motor Limits' , where it says 'Max Power Limit'. I lowered the value from 2000w to 550w.
That makes sense but I didn't know you could restore without having saved config first??? I di not save the original config so I don't think I can restore it. Willing to learn, tho!
Thanks for that tip, but I cannot find it anywhere. Firstly, it is hard to know what is the 'last screen' and I could not find any option to restore.
I see on the screen shots in this thread, a button that says "load default parameters". Not sure if that's it.
https://endless-sphere.com/forums/viewtopic.php?p=1607986
