You are right, the BMS includes two primary functions, low-voltage protection, and charge management/balancing. Originally, we had these functions split, into the LVC board, which handles the monitoring of each cell and turns off two big FETs that the main pack negative lead is connected through; and a Charger Management System, or CMS, which uses shunt-type voltage regulators on each channel that allows each cell to do the final CV portion of the charge cycle independently.
I have had a number of requests to do packs with the LVC board, instead of the BMS, because they intend to use indiidual cell chargers, with the 2A VoltPhreaks unit, or using multiple 10A 3-5V supplies. Others plan to charge using standard bulk CC/CV chargers and then occasionally use RC-styled balancers to externally balance the pack. Finally, I have also had requests to still do the external CMS unit, because these people will have multiple packs and they want to only have one charger and one CMS to share between the packs. I actually fall into the latter category as well. I have two 12-cell packs on my wife's bike, two new 12-cell packs on my Mariner folding bike and the 16-cell pack shown in the pics above is going on my Port Runner folding bike. I'm equiping all these packs with LVC boards, like the one shown below, and then doing a single CMS board, which will go in an extruded aluminum case. I'll use this CMS unit with 36V and 48V Soneil and Zivan chargers, on all the packs. Eventually, I will probably do a 2nd CMS unit, so that I can charge two 12-cell packs at a time, but initially, I'll just use the one.
This board is now mounted inside the pack and plugged into to another plug that has wires going to all the cell junctions. The front cover has a dummy plug attached to it, so that it plugs into the connector on the board. You can pop this cover off in order to get access to the multipin connector on the board. The CMS will have a cable coming from it with a matching multipin plug.
Anyway, I will try and offer pack versions to suit everybody's stated needs. I will begin selling LVC-equipped 12-cell 36V/10Ah and 16-cell 48V/10Ah packs today, and will start selling versions of both with the BMS, when it is ready. The 12-cell LVC pack will be $599 and the 16-cell will be $749. The 12-cell BMS version will be $685 and the 16-cell with BMS will be $875.
When they are ready, assembled and tested BMS units, will go for $135, for the 12-cell version, and $159 for the 16-cell unit. Both will come with heatsinks, a harness with a mulitpin connector and a separate set of wires with a matching multipin plug for connection to the cell junctions in the pack. They will also come with output leads that either terminate in a Deans connector, or standard PowerPole red/black connectors.
A fully assembled and tested CMS unit will go for $145. The board will be installed in a black anodized extruded aluminum box, which ends up supplementing the board-mounted heat sinks so that the current for the final phase can be cranked up higher than possible with the pack mounted BMS boards. The CMS unit will have an input connector for plugging in a standard CC/CV charger, like the Soneil 3610 and 4808 SRF-type chargers, and then an output cable, with a mulitpin plug, that goes into the matching recptacle-type connector on the pack-mounted LVC board.
Anyway, I will put up the LVC-based packs on my site today. I'll be final testing the CMS unit this weekend and will then make those available starting Monday. Bob should get new BMS boards today, so he will hopefully be doing the final verification tests on the BMS boards over the next few days as well. Once he's happy with the performance, I'll put them up on the site, and I'll make BMS-equipped 12-cell and 16-cell packs available.
I will also make the Soneil 3610 and 4808 4-4.5A chargers available next week as well. The 3610 SRF will be $135 and the 4808 SRF will cost $149.
-- Gary
