knightmb said:![]()
I want my electric motorcycle now with that many
maxwell said:Cells rated at 2.2Ah and 1.5C = 8x1.5*2.2 = 26.4A
Lithium-ion has a slightly higher internal resistance than nickel-based batteries. The cobalt system tends to increase the internal resistance as part of aging whereas the manganese (spinel) maintains the resistance throughout its life but loses capacity through chemical reaction. Cobalt and manganese are used for the positive electrodes.
High internal resistance will eventually render the battery useless. The energy may still be present but can no longer be delivered. This condition is permanent and cannot be reversed with cycling. Cool storage at a partial state-of-charged (40%) retards the aging process.
maxwell said:Because I have two packs when a cell goes lame only one pack would trip, then I can find the naughty one and replace it, having only 4 in parallel makes this a lot easier (and the trip more likely). Thats why I have spent a bit of time designing the BMS.
I must admire your bravery Xyster running all those cells in series without a BMS in a wooden box near your crown jewels!
I'll be watching your results closely, especially as I'm interested in doing the 60-amp controller mod w/variable current limit. If it's safe, I'd love to squeeze another 5 amps from my 18650s for 40 amps total, then add a 6s boost pack of emoli's or A123's on a relay for 96 volts. 4000 watts ought to get me up some of the hills around here much better than my present 2500 watts, which is kind of marginal with my hubmotor for sprightly climbing steep (>15%) inclines. I'm also hesitant to change a system otherwise working so well.Mine are next to my back and in an aluminium box, not worried a bit (tremble tremble). Only time will tell.
