okashira said:I can confirm the PF is NOT NCA. It is not LiNiCoAl.
They are actually NCM chemistry.
The PFs are great for taking abuse, but their calendar life will be inferior to the PD's if cared for properly.
flathill said:The PF is safer than the PD because it is not an NCA cell. The specs are exactly the same except calendar life is longer with the PD version. PF also has better low temp performance supposedly. The PF was designed to be a cheaper/safer drop in replacement for the PD in packs The PF version is NOT an NCA cell like the PD version
I'm GUESSING the BE and BD are setup the same manner in the product line, and have very similar performance specs, the only difference being the BD cell is the NCA version, while the BE cell is the Economy version (not NCA). This would explain the price difference.
I've only found no official documents saying the BE is a NCA cell. We can replicate the 12V overcharge test and know for sure by monitoring the cell temp. If the BE is an NCA cell it will get as hot as the BD cell.
x-speed said:okashira said:I can confirm the PF is NOT NCA. It is not LiNiCoAl.
what is the actual source of this Panasonic information about chemistry of PF being essentially different from PD ?
I found only assertions out of the blue from sellers and in forums (which seem to copy from each other).
Documents found with Panasonic mark so far don't tell about chemistry (change) at all - just a general document about the NCR product line declares them all as "NNP based", "_Nickel Oxide Based _New _Platform (NNP)" , "The new Nickel positive electrode excels in durability in actual use and charge retention" .
The pics "PF.PNG" and "spec.PNG" just show that the PF has all specs exactly the same as PD up to the last digit, the charge curve is same up to 4.2V, (and the discharge curve shapes are quite same on test sites, usual capacity spread and charge SoC inaccuracy taken into account). And the PD is removed from Panasonic site, replaced by PF.
Just the CID fuse of the PF trips very early upon overcharge, current jumps to zero and voltage to power-supply-max at 5V/50°C, which of course results in less temperature increase. All this doesn't indicate so far fundamentally different chemistry. Just a better overvoltage/overtemperature fuse mechanism? And perhaps minor improvements regarding durability.
Can properties and curves be so exactly same when the chemistry changes fully?
Is there any reliable source info which shows, that there are really 2 essentially different chemistries around within the Panasonic NCR line?
OK, I went and looked through everything again. (Ugh..)riba2233 said:So okashira, how do you explain cell tops, you haven't answered me?
flathill said:Yup the Tesla Model S is very likely the BE cell. That is the conclusion I came to in August on the Tesla forum before I got confused:
http://www.teslamotorsclub.com/showthread.php/34934-Pics-Info-Inside-the-battery-pack/page11
2014-08-24, 12:02 AM #102
magnet magnet is online now
Junior Member
Join Date
Oct 2013
Outside
Posts
76
"Can you get a picture of the negative terminal of an individual cell?
The Rav4EV uses the 2900 mAh NCR18650PD with a C shaped vent designed to break the bond wire on the terminal when it opens. The C shaped vent is pictured in the Tesla patent but more recent patents also describe a circle shaped vent.
Panasonic recently released the NCR18650BE cell which is also an NCA cell rated at 2C max just like the PD cell, but rated at 3300 mAh! This cell has the same triangular positive terminal as the PD cell but has a circular vent. No other Panasonic cells besides the PD and BE have negative terminal vents! The nominal voltage of a NCA cell is 3.65V so a 3.3 Ah cell would result in a 85.5 kWh pack
The 3400 mAh NCR18650B is a high energy cell not suitable for EV use. The latest high energy cell is the NCR18650G rated at 3600 mAh. Neither of these cells has the Tesla vent on the neg terminal."
As you can tell I am obsessed with knowing which cell the Model S uses. It could also be custom
Only person i know who managed to buy a wrecked Mod S, paid over $40k for it ! and Tesla are actively making it hard for people to reuse parts,..especially the electronics and drive components which many believe Tesla can disable remotely. !okashira said:I am still interested in getting a Model S / Pack. I wonder how much interest there would be on this forum to buy cells.
A group buy would be hard, as I have no reputation here. But I have the capital to just buy a car/pack and sell them if I can make a small profit for my labor.
Cephalotus said:This document (from Panasonic?) explains the difference between NCR18650PD and NCR18650PF
http://akkuplus.de/mediafiles//Datenblatt/Panasonic/Panasonic_NCR18650PF.pdf
To me all electrical specs look 100% identical, so I assume their chemistry is the same. There is a different CID and different style of vents.
best regards
piwhy said:I ordered few weeks ago from a "main" battery supplier on Alibaba different Panasonic NCR18650(A,B,BE,BD,PF) cells to make different tests on it and try to feel real differences between all these cells.
On first cycles, each cells seems to be compliant with their specs but I already made hundred of cycles on BD and BE cells and I'm a bit disappointed about the capacity drop over cycles @1C charge/1C discharge... I'm currently running the same cycles @ 0.5C charge/discharge, to compare.
These, are supposed to be "genuine" Panasonic cells, but as always on cells market, it's as playing russian roulette.
I will post my results soon but I will be pleased to compare with your results on cells from an other supplier.
okashira said:The lower performance of the PF compared to the PD at high current could be explained by the addition of this fuse you refer to.
EDIT: well, tests show the PF outperforms at high amps, (10A) PD slighly outperforms at 3A and they are very similar at low current (0.2A)
WTFknows.
This whole "B grade A grade" BS really makes comparisons difficult
Generally Panasonic reserves their "NNP" terminology for NCA chemistry cells. Do you have a link to this document?
okashira said:member fellow says he discharged his PF's to 0V, kept them there for a week, and they came back OK.
Surely NCA can't handle that?
x-speed said:The rather cheap NCR18650BE "3200mAh" is not a high drain cell as the "10A" NCR BD (subject of this thread) is. The BE is not even rated as 2C cell from Panasonic/Sanyo, but only 3.636A (1.2C), though R-AC 40mOhm is similar to NCR B:
Maybe kind of sort out's.
