d8veh said:
The BPM kit comes with a 30 amp controller, which is more than enough current, and I think he went for the Headway battery, which can give 60 amps. BMSBattery have now changed the way they sell kits, so you can mix and match components. The controllers with LCD displays (S12S 23 amps and S12P 29 amps) are a much better option than the KU123 because you can use the pedal sensor.
If I wanted a kit with this motor, I'd get the 48v 15 aH shrinktube LiMnNiCo battery, the S12S controller (plus LCD and wheel-speed sensor), torque arms, PAS, Thumb throttle and brake sensors (if cable brakes). The speed would be the same as above, and torque would be a bit less, which is more manageable. For correct gearing, you need a DNP rear gearset with 11T top gear, and a 48T crankset (Shimano M590).
Having said all that, the 500w CST motor is also very attractive and worth the extra money because it takes a standard cassette for much better gearing options. It's a 270 rpm motor, so about 22 mph at 36v and 30mph at 48v.
Hi d8veh, and thank you for your reply! I have probably read 100's of comments from you on ES the last month - so Im Grateful you take your time to look at my setup.
I don't think I am qualified to build my own battery from Headway batteries, I want a safe / stabel option - and good walue pack (2000+ cycles).
At the same time I want a small pack because I want to fit it in the frame of my bike, and have ordered a Nice top-tube bag for light/easy on the eye build.
Im 90 kg, need 25 km range (2x11 km home-work-home route) and want a bike - not a moped
Im now and then using the bike I plan to electrify (Hybrid 700c 7 gear aluminium bike) and manages to do one way at ca 25 km/h speed. I've tried the BH-emotions cross (?) With pedal assist up to 30 km/h and a 350 w rear hub (supposed to be "forced" Down to the legal 250w limit...but I dont know if i belive that..... This bike was Nice, - but to slow. The climbing ability was enough as I pedal all the way - and my commute is mostly flat /small hils up and Down. So I need something more powerfull witch can continue to support me a bit longer than the 30 km/h cutoff. How mutch more speed I want is difficult to say - as this is my first build and I hope to avoid regreting going for a to slow/weak build - so I Guess I want an engine that will give med speeds around the 45 km/h + mark... And I would like it to be "stealthy".... be able to Climb a litle bit if needed... and Im on a Budget.... Doable? Easy... straight forward...? Hehe... NO...
All I've acomplished by spending a lot of hours Reading and Reading at this fantastic forum is that I realice you need to know what your doing if you want your first build to be a good one, - and to actually give you the result you pictured when you started up. As a mather a fact Im mutch more insecure of how to do this now than I was before I wisited ES... !!
Well - this was my plan build:
1) Bafang BMP rear 500w/48v 328 RPM engine delivered in a 700c Wheel (I was planning to take the Whole standard kit - price dif is only $25 and I then get the Controller ++) : http://www.bmsbattery.com/ebike-kits/348-bafang-350watts500watts-bpm-motor-e-bike-kit.html
2) The S09P Controller (I dont understand the diference between sinwave or square wave - took the smalest one for easy install)
http://www.bmsbattery.com/controller/553-s06-250w-imitation-torque-square-wave-controller.html
3) The 48v/10ah LiFePO4 Battery at $259. (Its bigger than the $218 48v/10ah Li-Ion - but gives 2000 cycles - better value and still fits my framebag).
http://www.bmsbattery.com/48v/496-48v-10ah-lithium-ion-electric-bicycle-battery-pack.html
(The battery you suggest (48/15 Li-Ion was considered - but because I dont need long range and the Dimensions of the battery are not listed atBMSBattery.com (and only 800 cycles it lost out...) Do you know the Dimensions of this battery?
4)
The plus LCD,wheel-speed, torque arms, PAS (12/10/8/5 poles? - whats the difference - witch is best?) Thumb trottle and brake sensores are in my list to
Also disc-brakes for front and rearwheel, extra battery charger (one at home and one at work just in case...) exstra spokes (12g or 13g)?, extra throtle /PAS and brake sensors. I have also the 7 gear Shimano Freewheel on my list: http://www.bmsbattery.com/ebike-parts/48-14-28-teeth-shimano-freewheel.html
The DNP rear gearset With 11t topgear... or the 48T crankset ..... ?I have absolutely no idea of what this is - or why I need it?
I considered the CST 36v/500w kit - and run it at the 48v pack but, With a fair chance of not knowing what Im talking about I concluded that this is aimed more at "professjonal" bikers that are "hung up" at more Advanced gear-systems than I am... And from the rewievs from other BPM-users, they more or less seemd saisfied...
I have also considered going for CST 36v/500w With 48v bat/con... not because of this gearing-thing - but because I like the 270 RPM "basis" With exstra V....
But the price and Reading somewhere that its more efficient to run 48v at a 48 engine I droped it...
Im also a litle bit conserned about battery 15 amp continius discharge and a 30 amp (KU123) Controller / 23 amp (S09p) Controller... (?)
But I've seen many People using the KU123 at similar battery amps claiming it all Works like a charm...
Am also considereing buying the Speedict / android - thing to monitor/controll current and I love the Panic-button!
Well... a lot of questions here.... Hope to get some good answears.
Thanks - Agiator of Norway
