Hi Guys
Thought while I was online I would check other posts. Found this one
The 'wrong' throttle' was not so much wrong, but an attempt to extend power/range by controlling ramp up speed. Approx 50% of people have commented on it. For those who have one and do not like it >> Stiff
Only joking. Drop me an email with details and address and I will send 'standard' one to you at no cost.
As a result of this we are going back to supplying 'standard' throttle in kit, with energy saver throttle as option.
Chain Wear: This is one of those myths being driven by hub motor proponents (read sales person), along with chain drive because of gears being less "efficient" that hub systems.
OK, they caught us out.
AT LEAST AT FIRST GLANCE.
Here is the FULL fact. Yes gears do cause inefficiency compared to direct systems. BUT only 1-2% for gear types used on bikes. This is far out weighed by the fact that a direct drive bike is near on useless off a BMX track. Minor detail omitting the actual percentage by sales people; but hey they are still telling the "truth". Also remember gears allow the drive source to operate in peak range at more/most speeds, just like a car. So which system is less efficient !!!!!!!!!!!!!!!!!!
In regard to chain wear. For a given rider using the exact same ride pattern with chain drive or hub drive; again yes there will be "faster" wear. How much, don't know yet as people using our system and who have reported clocking over 2000km, SO FAR, have still not had to replace any drive component. So sorry cannot give definite answer yet, maybe next year, or the year after, or...
I think it is safe to say that you may have to replace your system say 5-10% earlier than if not used. But remember bikes are designed to carry larger loads that most people and tend to be over engineered to play it safe, so the amount of 'increased' wear I think is again over stressed by hub sales person.
Just one final note on this point; my experience. I have been using the same bike for prototyping and testing now for approx 3 years. It gets punished with everything possible, including 800W motor for 'fun'. It is a cheap Cheetah brand that retails for about AUD250. I have not replaced a single item on this, except for gear levers at the start as they were twist grip.
In relation to idler. A problem we had was sourcing just a deraliiuer idler (in volume) without having to by whole derailluer. This has now been acheived and all further kits will have a 11T idler with sealed bearing; a further example on our efforts to continue to improve where we can.
I would ask that you people, who are really the leading edge users for this market, contact me via forum AND DIRECT with any comments or suggestions you may have to improve the system or something that might be desirable to see on system. For example we are currently investigating the additon of an OEM meter as standard, hopefully without increasing cost too much (if at all).
Please don't count on me seeing these posts, if any poster could also email me direct that would be great. I will answer on forum then
Cheers
Allan
