Hi all.
I had it pointed out to me in PM that I speak authoritatively on Li batteries. So I'm a noob here in all ways but one .... I know way more than I ever wanted to know about lithium batteries due to part of my work responsibilities
. But, hey, I can contribute and not just be a sponge!
Couple golden rules on Li batteries
1) Never charge above the rated voltage. If it's a 4.2V cell never charge above that. (more below)
2) Never below 2.7.... or really about 3V. The lower you take it the more stripping you're doing of the copper of the anode, causing plating (capacity loss) and dendrite growth (can lead to a puncture and safety problem).
3) Limiting to 3.5V and 4.1V will greatly improve your cycle life. I've read of EV makers who limit their stuff to the middle third of available capacity to greatly increase cycle life.
4) Not using a BMS is dangerous.
This is actually a great summary of all the issues and at least the first couple pages match what I know.
http://www.mpoweruk.com/lithium_failures.htm
The reason for overcharging being an issue. Cell manufacturers are judged by their maximum capacity combined with reliability, but the first-most spec they get judged on ... what gets them in the door, is their energy density. To do that they push the voltages up as far as they can and have a reasonable 500 cycle life. There are various tradeoffs for safety, capacity, and lifetime. Some cells are better at some than others.
Here's a good article on that (and OMG did my head hurt reading that whole site):
http://batteryuniversity.com/learn/article/safety_of_lithium_ion_batteries
There are newer charging voltages in the market. 4.25V, 4.3, 4.35 and I recently saw projections of 5V. There's new cathode materials in development such as silicon based. But all of these trade off against longevity. Initial silicon packs are awesome... till you've cycled them about 100 times. Then they're trash (silicon lattice is too brittle and the intercalcuation of lithium ions forces the lattice to expand and break down your cathode material).
(for a 4.2V cell - and keep in mind this is what you're supposed to do, not what you can get away with ... I can drive my car at 100mph and get away with it ... usually)
I made an analogy in my head to help remember the effects. Think of your battery as a bus. There's only so many seats. If you charge to only 4.1V there's enough seats left that you can leave it there all day long and no problems. In a 4.1V charge you don't need to terminate because everyone on the bus is just so happy.
Now, if you fill every seat you start getting people mad. Some of them react by not behaving like you expect ever again (capacity loss due to plating and general wear of anode / cathode). But this is the normal and it's designed to handle that. You can do it safely. But eventually you need to shut off the doors to keep people from getting too many in the bus and causing problems. Thus, if you're charging to capacity it's important to do battery cut off.
Now ... just why don't you ever charge to above .... sure, you've got some more people on the bus but you do it at the cost of making a lot more of your people permanently mad (more of that plating of the aluminum from the cathode as well as the lithium plating - both permanent capacity loss). But there's a worse side effect. You can have a riot and meltdown of general order. That metal stipped out of the cathode (for overcharge, anode for overdischarge) ends up growing dendrites, or little metal spikes. Those spikes slowly grow and it's possible to push through the separator and short anode to cathode. Then you have a hard short inside the can .... and ... bad things happen then
. The bigger the battery the bigger the problem. There are lots of YouTube videos on people who decided it was a good idea to create that short the hard way (nail). It's not pretty.
Anyway, hopefully this can help someone.
